Allan
ENUM ID values not unique |
Posted: Sat Jun 05, 2010 11:21 pm |
Hi everybody,
I'm using 4.104 compiler version with a 18F2321.
I have the following declaration:
Quote: |
enum Modes{InternalMode, ExternalMode, EncoderMode, StandByMode};
When I mouse over this statement I get the wrong constant values -
InternalMode = 0
ExternalMode = 2
EncoderMode = 0
StandByMode = 0
The manual says:
" The ids in the list are each created as a constant. By default the first id is set to zero and they increment by one. "
I have a simple test if-else if statement that fails - it never gets to EncoderMode since it is exiting at InternalMode test.
if(CurrentMode == InternalMode)
Display = Display + 1;
else if(CurrentMode == ExternalMode)
Display = Display +2;
else if(CurrentMode == EncoderMode)
Display = Display + 3;
Any idea what's going on? Am I wrong to expect the mouse over to show the constants to be assigned 0 to 3?
Thanks, Al |
Posted: Sun Jun 06, 2010 12:54 pm |
The mouse-over would be some kind of IDE issue. The actual code works.
(You didn't say what IDE you're using).
I installed vs. 4.104 and compiled the test program shown below.
Here's the output from the MPLAB simulator. It's correct.
Quote: |
InternalMode: 0
ExternalMode: 1
EncoderMode: 2
StandbyMode: 3
#include <18F2321.h>
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
printf("InternalMode: %u\r", InternalMode);
printf("ExternalMode: %u\r", ExternalMode);
printf("EncoderMode: %u\r", EncoderMode);
printf("StandbyMode: %u\r", StandbyMode);
Then I made the test program shown below with your 'if-else' statements
and it gave this result, which is correct:
int8 CurrentMode;
int8 Display;
Display = 0;
CurrentMode = 2;
printf("Display = %u\r", Display);
Allan
Posted: Sun Jun 06, 2010 1:35 pm |
Hi PCM programmer,
I just compiled your code and it still gives me wrong ID's. I'll reload CCS's IDE and post if that does not solve the problem.
Thanks for your help.
Al |
Allan
Posted: Sun Jun 06, 2010 3:15 pm |
Hi everybody,
Reloading the compiler and CCS' IDE (now V. 4.103) did not solve the problem, but I found an interesting clue.
I simplified the code as much as possible
#use delay(clock=10000000)
I get the correct ID values (0,1,2,3) when I compile the code. It is only after I turn on the ICD-U64 debugger that I get the problem.
The correct compiler mouse over has black lettering on a light blue background, The incorrect mouse over with the IDE uses blue lettering on a yellow background. Different software!
I think the problem is in the ICD-U64. I'll try the programmer at work tomorrow and see what happens.
Al |
semaphore
Posted: Thu Jul 01, 2010 10:47 pm |
I've the same problem here. I'm using CCS IDE version 4.107 and PCB, PCM, PCH, PCD version 4.107 with ICD-U64. Please help. |
Allan
Posted: Fri Jul 02, 2010 6:30 am |
semaphore wrote: | I've the same problem here. I'm using CCS IDE version 4.107 and PCB, PCM, PCH, PCD version 4.107 with ICD-U64. Please help. |
The best work around is to define each ENUM value as a constant.
Foe example, use
Quote: |
const int8 InternalMode=0, ExternalMode=1, EncoderMode=2, StandByMode=3;
instead of
This works fine. I'll keep bugging CCS about this until get a response.
Al |
semaphore
Posted: Sat Jul 03, 2010 8:30 pm |
Thanks Al,
I like to see this fix as well. It just kind of bug me that the simple enum doesn't work the way it should. |
Posted: Sun Jul 04, 2010 3:01 am |
The thing is that the enum does. It appears to be a problem with the way that the IDE 'understands' enum values. Have used many dozens of enum's with a hardware ICE, and in real code, and the values are right. It is only in the IDE debugging environment, that the values go wrong....
ForrestJohnson
Having the same problem. |
Posted: Fri Jul 09, 2010 4:36 pm |
Ya, I've spent quite a bit of time dealing with this problem and it seems like it cascades into other areas causing more debugger-related problems. Like arrays of structs containing enums are showing incorrect data and size. |
