timer1 on 12F683
filjoa
timer1 on 12F683
PostPosted: Fri Jun 04, 2010 12:26 pm     Reply with quote
Hi
I like try start use timers but I don't find anywhere equations to calculate overflow happens.
Someone can explain to me how I can calculate timers interruption?
PS: Now I try to flash an LED (is possible flash with 1s?)...
#include <12F683.h>
#FUSES NOWDT, INTRC_IO, NOCPD, NOPROTECT, NOMCLR, PUT, NOBROWNOUT, NOIESO, NOFCMEN
#use delay(clock=8000000)
#define LED PIN_A5
int16 count = 0;
#int_TIMER1
void  TIMER1_isr(void)
   count++;
int8 aux = 0 ;
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
    if (count >= 1000)
       if (aux == 0)
                 output_high(LED);
                 aux = 1;
                 count = 0;
                } else
                        output_low(LED);
                        aux = 0;
                        count = 0;
best regards
PostPosted: Fri Jun 04, 2010 2:24 pm     Reply with quote
First read Newguy's tutorial on timers:
http://www.ccsinfo.com/forum/viewtopic.php?t=22467
Then read this tutorial on Timer1:
http://www.microcontrollerboard.com/pic-timer1-tutorial.html
If you still have questions, then ask.
Microchip -- Timer0 Tutorial
http://ww1.microchip.com/downloads/en/DeviceDoc/51682A.pdf
Microchip -- Timer0 Tutorial (Part 2)
http://ww1.microchip.com/downloads/en/DeviceDoc/51702A.pdf
