Why wont pin toggle???
arloedx
PostPosted: Fri Jun 04, 2010 10:18 am     Reply with quote
I am trying to make PIN_A4 of a PIC18F252 toggle from low to high but it will not work. I try the same code on PIN_A3 and it works perfectly. What am I doing wrong???
#include <18f252.h>
#use delay(clock=10000000)
   setup_port_a(NO_ANALOGS); //no analog inputs
   set_tris_a(0x00); //all outputs
      output_low(PIN_A4);
      output_low(PIN_A3);
      output_high(PIN_A4);
      output_high(PIN_A3);
mkuang
Reply
PostPosted: Fri Jun 04, 2010 11:14 am     Reply with quote
On page 10 of the PIC18F252 datasheet it says regarding RA4:
Digital I/O. Open drain when configured as output.
You will need external pullup for it to work. Also you don't need this line:
The compiler set the direction of the pins for you when you use the output_high function.
