ocean-server compass
ronnarone.r
PostPosted: Thu Jun 03, 2010 10:29 pm     Reply with quote
#include <18F8722.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdlibm.h>
#include <string.h>
#include <math.h>
#fuses HS,NOPROTECT,NOLVP,NOBROWNOUT
#use delay(clock = 10000000)
#use rs232(baud =38400,xmit=pin_C6,rcv=pin_C7,PARITY=N,bits =8,RESTART_WDT,stream=Ocs,errors)  //ocean_server
#use rs232(baud =9600,xmit=pin_G1,rcv=pin_G2,PARITY=N,bits =8,RESTART_WDT,stream=GPS,errors)   //LEA-4S
#use rs232(baud =38400,xmit=pin_E0,rcv=pin_E1,PARITY=N,bits =8,stream=HOSTPC,errors)//Computer
#define N   1
#define S  -1
#define E   1
#define W  -1
#define f   1/297
#define lat_1 13.50    //Decimal Degree
#define lon_1 100.30   //Decimal Degree
    char NmeaSentence[100];
    char Fixsentence[]="GPRMC";
    char k ; // Character in NMEA
    char NMEA ;
    int i=0;
     double lat1 ;
     double lon1 ;
    char latitude_longitude_LEA_4S[26];
    char lat_dd_LEA_4S[3];
    char lat_mm_LEA_4S[10];
    char lon_dd_LEA_4S[4];
    char lon_mm_LEA_4S[10];
    double lat_d_LEA_4S ;
    double lat_m_LEA_4S ;
    double lon_d_LEA_4S;
    double lon_m_LEA_4S;
    double lat_2;
    double lon_2;
    double lat2 ; //Rad
    double lon2 ; //Rad
   int16 f_4 ; //T. Vincenty " Inverse Formula " Alfa_1
   double U_1 ;
   double U_2 ;
char compass_raw[7];
char buffer_ocs[80];
int16 compass;
int select;
signed int16 Azimuth;
void readMessage_Ocs(void);
void calulation(void);
void readMessage_Ocs()
      fgets(buffer_ocs,Ocs);
      for(select=3; buffer_ocs[select] != 'P'; select++)
         compass_raw[select-3] = buffer_ocs[select];
            fprintf(HOSTPC,"%c",compass_raw[select-3]);
            bit_clear(buffer_ocs[80],31);
            bit_set(buffer_ocs[80],31);
            fprintf(HOSTPC,"\n\r");
         compass = atol(compass_raw);
            fprintf(HOSTPC,"compass=%lu\n\r",compass);
void calulation()
   lat1 = (lat_1)*(pi/180)*(N);
   lon1 = (lon_1)*(pi/180)*(E);
   do
           while ( fgetc(GPS) != '$' );
           for   (k=0;k<6;k++)
           NmeaSentence[k]=fgetc(GPS);
   while (strncmp(NmeaSentence,Fixsentence,5)!=0);
           k = 0 ;
           NMEA = 0 ;
   while (NmeaSentence[k] !='*' && k<79 )
           NMEA = fgetc(GPS);
           NmeaSentence[k++] = NMEA ;
   for ( i= 12; i<= 37;i++ ) //1239.60366,N,10057.25350,E
            latitude_longitude_LEA_4S[i-12]= NmeaSentence[i];
            fprintf(HOSTPC,"%c" ,latitude_longitude_LEA_4S[i-12] );
   for ( i= 0 ; i<2;i++ )
             lat_dd_LEA_4S[i]= NmeaSentence[i+12];
             lat_d_LEA_4S = atof(lat_dd_LEA_4S);
             fprintf(HOSTPC,"lat_d_LEA_4S=%f \n\r",lat_d_LEA_4S );
  for ( i= 0 ; i<6;i++ )
             lat_mm_LEA_4S[i]= NmeaSentence[i+14];
            lat_m_LEA_4S = atof(lat_mm_LEA_4S)/60;
            fprintf(HOSTPC,"lat_m_LEA_4S =%f \n\r" ,lat_m_LEA_4S );
             lat_2 = (lat_d_LEA_4S + lat_m_LEA_4S)*N;             //Decimal Degree
             fprintf(HOSTPC,"lat_2 =%3.7f \n\r" ,lat_2 );
             fprintf(HOSTPC,"lon_dd_LEA_4S[i]=" );
    for ( i= 0 ; i<3;i++ )
             lon_dd_LEA_4S[i]= NmeaSentence[i+25];
             fprintf(HOSTPC,"%c" ,lon_dd_LEA_4S[i] );
             fprintf(HOSTPC," \n\r");
             lon_d_LEA_4S =  atof(lon_dd_LEA_4S);
             fprintf(HOSTPC,"lon_d_LEA_4S =%f \n\r" ,lon_d_LEA_4S );
             lon_mm_LEA_4S[i]= NmeaSentence[i+28];
             lon_m_LEA_4S =  atof(lon_mm_LEA_4S)/60;
             fprintf(HOSTPC,"lon_m_LEA_4S =%f \n\r" ,lon_m_LEA_4S );
            lon_2 =   (lon_d_LEA_4S + lon_m_LEA_4S)*E ;         //Decimal Degree
            fprintf(HOSTPC,"lon_2=%3.7f \n\r" ,lon_2 );
void main ()
while(true)
readMessage_Ocs();
calulation();
Output for compass has error. But when I run only compass function, it works and I can not change baud rate. I want to know why ? Thank you.
PostPosted: Fri Jun 04, 2010 5:08 am     Reply with quote
I don't know what you want to do here, but whatever it is it is a bug.
buffer_ocs has a length of 80, meaning the last item in the buffer is buffer_ocs[79]. Also, it is an 8-bit array so when setting bit 31 of buffer_ocs[80] you are actually writing to bit 8 of buffer_ocs[83].
You are writing outside the array, corrupting other variables in RAM with unpredictable results.
You have this construction several times in your code. atof() expects a string as input, i.e. a null terminated string of characters. This zero terminator is missing causing unpredictable output for atof().
This will fail in two situations:
1) When the string is shorter than 3 characters
2) When the string does not contain a 'P' character
