10f222 pullup?
hmmpic
10f222 pullup?
PostPosted: Wed Jun 02, 2010 12:57 pm     Reply with quote
How to use the weak pull up on this chip?
From the data sheet there is a GPWU bit in the OPTION reg.
But the command port_x_pullups won't work?
PostPosted: Wed Jun 02, 2010 1:10 pm     Reply with quote
Use the set_options() function to do this. The link below shows the
macro for that function. For the function parameter, use the value that
you want to set the OPTION register to. Look in the 10F222 data sheet
for a description of the bits in the OPTION register.
http://www.ccsinfo.com/forum/viewtopic.php?t=42414&start=2
Here is another example:
http://www.ccsinfo.com/forum/viewtopic.php?t=42138&start=6
hmmpic
PostPosted: Wed Jun 02, 2010 1:35 pm     Reply with quote
Thanks for your help!
