FPUTC execute time
Manel28
FPUTC execute time
PostPosted: Wed Jun 02, 2010 9:19 am     Reply with quote
Hi, Im havin some troubles using fputc command.
Im trying to simulate a transmission of bytes by using a 18F8722 and proteus isis. The thing ist that my scheme must meet some time conditions between bytes, I mean, the time between bytes should be less than 700microsec. Ive seen in proteus that the time of the fputc execution is more than expected. when I do :
for(i=0;i<=lenbuff-1;i++)
fputc( buff[i],dirCam );
Than it takes like 1 msec to execute fputc and i would like to reduce the time interval. I was thinking of increasing the clock frequency since im working right now at 4Mhz but even at 20Mhz it seems to take the same time in proteus. some suggestions? Thank u
PostPosted: Wed Jun 02, 2010 9:33 am     Reply with quote
The time is totally determined by the serial port baud rate.
The first time you call fputc, the byte is immediately transferred into the output shift register. The second time, it goes into the one character buffer. The third time, fputc, has to wait for the _first_ byte to complete sending, before it can be sent. From this point on, every write takes one charachter time.
Look at ex_stisr.c
This shows how to implement an interrupt driven software buffer to send data out the port. Transfer times of a few uSec (provided you have buffer space).
