probleme void defilement
ahmeddragonbleu
PostPosted: Sat May 29, 2010 2:05 am     Reply with quote
when i compile this warning apper to me "line 535 code has no effect "
i==i-30 has no effect
i need a solution
THE PROGRAMM
#include <16F877A.h>
#fuses XT, NOLVP, NOWDT
void defilement(int i)
if(i>29)
i==i-30;
mini_main(i);
576 line program chopped down
to needed part.
-- Forum moderator
Last edited by ahmeddragonbleu on Sat May 29, 2010 7:52 am; edited 1 time in total
PostPosted: Sat May 29, 2010 3:40 am     Reply with quote
Post small programs. 95% of the posted code has nothing to do with the problem.
i=i-30 has no effect
i==i-30;
Spot the difference in these two lines...
What did you intend and what did you actually write?
ahmeddragonbleu
PostPosted: Sat May 29, 2010 7:54 am     Reply with quote
when i compile this warning appear to me "line 535 code has no effect "
i need a solution
if(i>29)
i==i-30;
mini_main(i);
PostPosted: Sat May 29, 2010 8:37 am     Reply with quote
The answer has already been pointed out...
The statement :
i==i-30;
says 'test if i equals i-30', then as written, the result of the test is thrown away.
It has no effect. The compiler is telling you _exactly_ what is going on...
PostPosted: Sun May 30, 2010 3:37 am     Reply with quote
As an answer to your question in: http://www.ccsinfo.com/forum/viewtopic.php?p=133077
Check your study book on the C language and look up the difference between the '=' and '==' operators.
