USB - PIC Organic or FTDI?
jecottrell
PostPosted: Fri May 28, 2010 5:29 pm     Reply with quote
I need a USB vitual serial port and have had good results with the FTDI parts. I was wondering how difficult it is to use a PIC USB part and implement the same without the FTDI part?
Any words of wisdom?
Thanks,
John
Rohit de Sa
PostPosted: Fri May 28, 2010 11:45 pm     Reply with quote
Pretty easy if you've got a PIC18F2550 or 18F4550.
Do you want to use the PIC as a USB-to-serial converter? That would mean editing ex_usb_serial.c in the examples folder. Basically, the examples provided by CCS allow you to implement the USB-to-serial converter on the microcontroller itself.
You could still make a simple USB-to-UART device by modifying the example mentioned. But if you require a standalone virtual serial port with all the handshaking lines, I would recommend going with the FTDI chip - writing code for such a device may be too much of a hassle.
Rohit
PostPosted: Sat May 29, 2010 12:15 am     Reply with quote
The benefit of PIC implementation of virtual com port is for applications, that need functionality beyond a simple serial interface.
If I understand right, this also the case in your application. In my opinion it's pretty easy, I don't see a need for an additional
FTDI chip for similar designs.
Eddy71ua
PostPosted: Tue Jun 01, 2010 11:58 am     Reply with quote
What to do if you want to use the DTR, RTS, Ri ?..
jecottrell
PostPosted: Tue Jun 01, 2010 3:12 pm     Reply with quote
No. Just need Tx and Rx.
I was just reading about the serial stuff for USB in the latest compiler manual.
Looks like this may be the ticket.
Thanks,
John
