Problem with delay_ms on PIC18LF
jafeucht
PostPosted: Fri May 28, 2010 2:42 am     Reply with quote
I am having a bit of trouble with the strangest error. The error happens after I upload the following code to a PIC18LF4525 40-pin DIP using a SUPERPRO 580U programmer.
#include <18F4525.h>
#device adc=8
#fuses NOWDT,WDT128,HS,NOPROTECT,NOIESO,BROWNOUT,BORV21,PUT,NOCPD,STVREN
#fuses NODEBUG,NOLVP,NOWRT,NOWRTD,NOEBTR,NOCPB,NOEBTRB,NOWRTC,NOWRTB,NOFCMEN
#fuses XINST,NOPBADEN,LPT1OSC,MCLR
   unsigned int i;
   setup_psp(PSP_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   while (1) {
      puts("Hello, world");
   return;
The problem is when I actually run this code, the I2C interrupt is never called, and the delay_ms(1000) line seems to be ignored, so I get rapid "Hello, world"s on my serial port monitor. Is there any reason why the delay_ms statement would be ignored in this code? Is anybody running into this same problem?
Thanks in advance for your help.
PostPosted: Fri May 28, 2010 4:42 am     Reply with quote
Change one fuse. XINST -> NOXINST.
CCS does not support XINST, and if this fuse is selected, you will get indeterminate errors...
jafeucht
That worked
PostPosted: Fri May 28, 2010 7:03 am     Reply with quote
Wow, that worked. Thanks a lot! I just about pulled all my hair out over that.
Laughing
PostPosted: Fri May 28, 2010 8:43 am     Reply with quote
You did the 'critical thing', of posting a small test program with the problem.
This is why you will see some of the 'gol hands' here asking for this like a mantra. It really is vital. The problem is so often 'hidden' somewhere in the fuses, or setup lines, and not in the actual part of the program where it appears to be....
