128x64 GLCD odd behavior
sapy44
PostPosted: Wed May 26, 2010 12:40 pm     Reply with quote
Hello All,
I've been working with a KS0108 based GLCD. In the past I've been able to work with this GLCD with no issues, but recently I've fired it back up and found some odd behavior.
I can fill the screen with glcd_fill() function so I know that the individual pixels and memory locations are ok. However when I try to draw shapes like lines, rectangles, circles, etc. I get some random pixel errors.
When I single step through the code I can see that some pixels are being set ok, but when subsequent pixels are set, some of the previously set pixels are cleared.
I have a feeling that when the glcd_pixel() function reads back the memory location contents it is corrupting the data. Then when the glcd_write() function is called to set the individual pixel, it is upsetting the previously drawn pixels.
Please excuse the fact that I did not post any code, but I am just using the included driver glcd.c
Has anyone ever encountered this sort of behavior before ? If so, any suggestions on how to fix the problem ?
PostPosted: Wed May 26, 2010 3:06 pm     Reply with quote
What's your CCS compiler version ?
Also, what's your PIC ?
MikeP
PostPosted: Wed May 26, 2010 8:17 pm     Reply with quote
Please read and apply the fixes in this post if you are using the SED1335.c driver.
http://www.ccsinfo.com/forum/viewtopic.php?t=21096
sapy44
GLCD info
PostPosted: Sun Jul 18, 2010 12:54 am     Reply with quote
Compiler version 4.066
PICs used are 18F4685 and 18F4620
using the standard GLCD driver from CCS
