Oli Guest
using #FILL_ROM to add safety backup on PIC24 |
Posted: Wed May 26, 2010 3:50 am |
Hi All
I'm looking to fill all the unused space on the processor with an instruction that will 'recover' the program if it goes into the weeds. I guess I have 2 options
1/ use a reset instruction, which will reset the whole processor (I think this is the best option)
2/ use a GOTO instruction to point it to the beginning of the program.
Are there any best practices in doing this? Could somebody also point me in the direction of how to implement this i.e. calculating the hex values.
Many thanks |
Jerson
Joined: 31 Jul 2009 Posts: 122 Location: Bombay, India
Posted: Wed May 26, 2010 8:46 am |
Have you considered using the watch dog timer in your pic? It's meant for things like this. _________________ Regards
Jerson Fernandes |
bkamen
Posted: Wed May 26, 2010 7:29 pm |
Watchdog is the way to go.
Oli Guest
Posted: Thu May 27, 2010 9:14 am |
I'm already using it, but I asked because this is actually specified in the PIC24F WDT timer reference
Quote: | Question 2: What are good techniques for using the WDT in my application?
Answer: There are many techniques for using the WDT to prevent applications from locking up
or running away. When they are carefully analyzed, most of them depend on three basic princi-
ples:
1. Use one, and only one, CLRWDT instruction in your application. Placing multiple
occurrences throughout the application makes it more difficult to troubleshoot time-out
issues.
2. Place the CLRWDT instruction inside the main body of the application and not inside a
subroutine or an Interrupt Service Routine (ISR). If the instruction is located inside a
frequently called routine, there is a good chance that the WDT will constantly be reset and
never time-out.
3. Once the application is compiled and sized, place unconditional branch instructions (such
as, “GOTO .”) throughout the unused area of program memory. If something should hap-
pen that makes the code “run away” by branching into unused code space, the GOTO
instructions can bring the microcontroller back to your code, where the WDT can help
bring the application back under control. |
Perhaps filling it with NOOPS (0x00?) would be more suitable? |
bkamen
Posted: Thu May 27, 2010 9:17 am |
Ahhh..
Well, if you're going to fill ROM with a value, fill it with the opcode to jump/goto/branch to the reset location OR (maybe better) to a loop in memory that lacks the WDT reset. (I forget what it is.)
IIRC, when you erase the device, the default opcode is NOP. (I think)
FvM
Posted: Thu May 27, 2010 10:58 am |
I don't think, that it's necessary to fill the ROM under normal condition. I also don't like it, because it would increase the size of firmware image files. WDT operation should be sufficient in most cases. In addition, you can "guard" critical functions or code parts, e.g. the code triggering the watchdog or writing to flash/EEPROM by preceeding while (1); or reset_cpu(); calls. |
bkamen
Posted: Thu May 27, 2010 11:14 am |
I've never had to fill either.
I do find the recommendation he found interesting though.
SET
Posted: Fri May 28, 2010 9:01 am |
I think the recommendation is for a scenario where 'out of control' code might actually execute the watchdog kick, and therefore will never recover. If 'Goto here' instructions were executed then it's guaranteed that the timer would expire and do a reset. |
balmer
Posted: Mon May 31, 2010 5:59 pm |
In the event that code runaway occurs, the MCU could continue accessing memory until it reaches
an illegal address where, finally, a system reset will occur.
In the meantime, many undesired events could happen as a result of the code running where it should not.
To protect from the potentially harmful effects of code runaway, it is generally good practice to fill unused memory
with known values such as software RESET op-codes, SWI, or NOPs. |
Posted: Tue Jun 01, 2010 2:03 am |
Key is that the manufacturers of the chip have taken care of this for you.
The important things for the 'fill' instruction are:
1) It must not reset the watchdog.
2) It must not affect any I/O.
Obvious candidate is 'NOP'.
Microchip, on all their chips have made the reset memory value '0xFF', a NOP.
This is deliberate, and avoids the need to write anything into erased memory.
bkamen
Posted: Tue Jun 01, 2010 6:49 am |
The problem with the NOP is that if it's encountered somewhere in between code, the cpu can slide into another section of code.
So the default NOP is not really an answer for the truly paranoid.
Posted: Tue Jun 01, 2010 8:02 am |
This then simply 'behoves you' to always put a dummy leader in front of such code sections. The only one that is likely, is a bootloader at the top of memory, and I do exactly this.
There was a 'rule' years agao, that any code containing a watchdog reset, or calling a watchdog reset, should have a single instruction in front of it, that either jumps back to address zero, or jumps round it, to prevent 'walkthrough'. This is still good advice.
Filling the ROM, though it sounds nice, increases programming time so much, on some chips, that it really has to be avoided.
Oli Guest
Posted: Wed Jun 02, 2010 4:51 am |
I think I will leave it as it is. Thanks for your replies and advice
Oli |
