PIC18F2553 and SD Card using ex_mmcsd.c
SpoonBilly
PostPosted: Tue May 25, 2010 1:53 am     Reply with quote
I am not new to PIC18F2553 and CCS compiler, but I am new to PIC+SD/MMC. It is interesting to find that example is available and a lot of people are discussing about it. I gave the "ex_mmcsd.c" a try, and constantly check the SD card memory content using WinHex. I have been successfully read and write data from and into the SD card, but I found out that there is a 0x10E00 shift of the address. For example, if I am to read the data from address 0x00000000, I have to use address = 0x00010E00 to actually read the correct value. Anyone have any idea about this? Thanks.
Details:
Compiler Version: PCWHD 4.093
SD card capacity: 2GB (SanDisk)
SD card cluster size: 512 Byte
SD card file system: FAT32
PIC18F2553 Clock: 20MHz
PIC18F2553 Voltage: 3.3V
#include <18F2553.h>
#fuses NOWDT, HS, NOPROTECT
#use     delay(clock = 20000000)
#use     rs232(baud = 57600, xmit = PIN_A0, rcv = PIN_A1, invert)
#include <stdlib.h> // for atoi32
//meda library, a compatable media library is required for FAT.
#use fast_io(b)
#use fast_io(c)
#define MMCSD_PIN_SCL     PIN_B1 //o
#define MMCSD_PIN_SDI     PIN_B0 //i
#define MMCSD_PIN_SDO     PIN_C7 //o
#define MMCSD_PIN_SELECT  PIN_C6 //o
#include <mmcsd1.c> // modified mmcsd.c
#include <input.c>
   BYTE value, value_r, value_w, cmd;
   int32 address;
   printf("\r\n\nex_mmcsd.c\r\n\n");
   if (mmcsd_init())
      printf("Could not init the MMC/SD!!!!");
      while(TRUE);
   for(address = 0x00010E00; address <= 0x00010E0F; address++)
      mmcsd_read_byte(address, &value) ;
      printf("Add, %lX , Val, %X\n\r", address, value) ;
   do {
   } while (TRUE);
Part of the mmcsd.c was modified as such to fit with hardware SPI of PIC18F2553 and saved as mmcsd1.c:
#ifndef MMCSD_PIN_SCL
#endif
This is what I observed from WinHex:
_offset__|__value
00000000 EB
00000001 58
00000002 90
00000003 4D
00000004 53
00000005 44
00000006 4F
00000007 53
00000008 35
00000009 2E
0000000A 30
0000000B 00
0000000C 02
0000000D 01
0000000E 7E
0000000F 18
This is what I got from Terminal:
2ex_mmcsd.c
Add, 00010E00 , Val, EB
Add, 00010E01 , Val, 58
Add, 00010E02 , Val, 90
Add, 00010E03 , Val, 4D
Add, 00010E04 , Val, 53
Add, 00010E05 , Val, 44
Add, 00010E06 , Val, 4F
Add, 00010E07 , Val, 53
Add, 00010E08 , Val, 35
Add, 00010E09 , Val, 2E
Add, 00010E0A , Val, 30
Add, 00010E0B , Val, 00
Add, 00010E0C , Val, 02
Add, 00010E0D , Val, 01
Add, 00010E0E , Val, 7E
Add, 00010E0F , Val, 18
Update: 20100525
Tried it with a 1GB SD card (Apacer), FAT32 and cluster size 512 byte. The address shift is 0x0001F200.
Douglas Kennedy
PostPosted: Tue May 25, 2010 10:05 am     Reply with quote
There is a physical address and a logical address. The logical address is retrieved from the boot record. FAT ( Microsoft copyright) if you were to ask them is probably using logical addresses. Even though Microsoft is the only lawful owner of FAT technology on any platform much information is available in the public domain. Microsoft has made FAT licensing available for $250,000.
gogu2000
Re: PIC18F2553 and SD Card using ex_mmcsd.c
PostPosted: Tue Nov 09, 2010 10:01 am     Reply with quote
Hello, Please tell me what is your SPI clock. I use this code in a 18f4550 and I have some problem. Address in Winhex is at Offset column? TY.
SpoonBilly
PostPosted: Tue Nov 09, 2010 7:08 pm     Reply with quote
Not sure what do you mean by SPI clock, I don't think I modified any SPI setting. I'm using 20MHz crystal and delay(clock = 20000000).
Yes. Address in Winhex is at Offset column.
