Another SPI problem (CS5463)
Goto page Previous  1, 2, 3  Next
matt1eg
PostPosted: Mon Feb 09, 2009 3:38 pm     Reply with quote
Oh yeah forgot to mention that I noticed that. Was just getting 0 for a while but then noticed it, I have it as 2 now, this is when I get -128.
PostPosted: Mon Feb 09, 2009 3:42 pm     Reply with quote
Print the entire int32 returned value in Hex and see what you get.
Here are the required changes to do that:
temp32 = CS5463_read_reg(CS5463_TEMP_REG);
// temp8 = make8(temp32, 3); // Get upper byte of temp32
printf(lcd_putc, "\f Temp32 = %LX", temp32);
matt1eg
PostPosted: Mon Feb 09, 2009 3:58 pm     Reply with quote
I get 000000. It's either really cold here and I haven't noticed or its not measuring the temperature.
One other thing I did to modify your code was to send a command to start conversions. In the data sheet it said that it measures the temperature during continuous conversions.
   CS5463_write_command(0xE8);
   //temp8 = make8(temp32, 0);  // Get upper byte of temp32
   //printf(lcd_putc, "\f Temp = %d", temp8);
It also says
Once a temperature characterization
is performed, the temperature sensor can then be
utilized to assist in compensating for temperature drift.
I am unsure if this means that it for that particular use it needs characterization(which I assume means setting the temp offset) or if this is needed for any measurements to be done?
PostPosted: Mon Feb 09, 2009 4:13 pm     Reply with quote
It might be that temperature data is only available as a side effect of
some other operation (such as reading or using the ADC). I don't have
time to research this now. I've got to do some work for the company.
matt1eg
PostPosted: Mon Feb 09, 2009 4:17 pm     Reply with quote
Thats ok you don't have to worry I will see what happens when I get it doing proper calculations and post an update later this week.
spelltwister
PostPosted: Thu Feb 12, 2009 10:25 am     Reply with quote
Greetings,
I believe I have followed everything done here and am still having problems :/ I have scoped all values that are being sent from the uC (HCS08QG) and they are correct. However, I am only getting 0 from the cirrus chip. I had RESET float and tied it high. This got rid of the error of random pulses being sent out of the cirrus chip. Thx ;D
I've tried using the auto Chip Select feature and manual chip select feature to drive the CS pin high after each byte and I've tried driving it high after each operation (cs_low, read, 3 writes, cs_high). I have the signal coming in at about 4464 Hz. I have also tried running at 1 MHz. Same results.
Summary of what is done:
void reset_spi(){
  write_spid(0xFF);
  write_spid(0xFF);
  write_spid(0xFF);
  write_spid(0xFE);
char read_spid(void){
 write_spid(0xFF);
 while(!(SPIS & 0x80));//wait for full buffer
 return SPID;
void page_and_read_register(char page, char ra, char* buff){
if(page != cur_page){
     change_page(page);
     cur_page = page;
 write_spid(ra<<1);//which page to read
 buff[0] = read_spid();//SYNC0
 buff[1] = read_spid();
 buff[2] = read_spid();
main(){
int counter = 0; //look at many registers
char data[5];
reset_spi();
write_command(0xE4);//continuous conversions
while(1){
  page_and_read_register(0, counter, data);
  if(counter++ >= 15)//cycle thru registers 0 - 15 to see if anything has data
      counter = 0;
I have tried setting the register I'm reading to V_Instant, Temp, config, etc and they all give back the same nothingness. I am using a logic analyzer also to see the waves leaving and entering the cirrus chip and uC. The waves leaving the uC see OK, but the cirrus chip seems like it's doing nothing. I tested the clock on the cirrus chip and it correctly reports 4.096MHz.
Any help is greatly appreciated!!![/code]
matt1eg
PostPosted: Thu Feb 12, 2009 12:05 pm     Reply with quote
Hi
I'm no expert but looking through your code I can see some problems, although I have only worked with PICs and CCS compiler, I am not familiar with uC 'HCS08QG' at all, and are you using CCS compiler? If not My advice may not suit your application completely.
will not do continuous conversions you need 0xE8. Also here
you need to send the SYNC1 command where as you are not sending anything.
I would just start by trying to read one register at a time no cycling through them.
Where in your code are storing the bytes you have read?
I would of also said that you need to set up the SPI. In mine you can see I use
setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_16);
where the SPI_Mode is defined by
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
You need to make sure data is being clocked in and out at the times. The timing diagram in the CS5463 datasheet shows you the timings.
This
void reset_spi(){
  write_spid(0xFF);
  write_spid(0xFF);
  write_spid(0xFF);
  write_spid(0xFE);
won't reset its an attempt to reinitialise but you need to drive CS pin high then low with the above code to do this. You need to have a seperate reset and cs pin. You have said that you use the reset pin thats good I use this at start up and then I just use CS low to initialise comms then when I'm done drive it high.
I do this after each command is carried out, e.g. when I do a read I set it low then do the read (write the register and read 3 bytes of data) then set it high. This works fine for me.
Like I said I am no expert but I think the pointers above should help.
avarachan
CS5463 with microchip 18f67j60
PostPosted: Mon May 24, 2010 12:42 pm     Reply with quote
I am working with the CS5463 and microchip 18f67j60. I have already gotten CS5463 working with pic 18f2620, but at 4 MHz. My new processor has a crystal of 25MHz. I can write data to the CS5463, signal looks good, I am following all the initialization, synchronization etc, as I did with 18f2620. The problem is I can't get data out from the CS5463. It always reads zero. Though, intermittently I can see a pulse on the SDO of CS5463.
Any suggestions would be greatly appreciated.
AVC
PostPosted: Mon May 24, 2010 1:08 pm     Reply with quote
The SPI clock from the PIC's MSSP hardware module is derived from
the oscillator of the PIC. If you increase the PIC oscillator frequency,
then you increase the SCLK frequency.
Download the CS5463 data sheet:
http://www.cirrus.com/en/pubs/proDatasheet/CS5463_F2.pdf
Look at the SPI specifications on page 11. It has a fairly low SCLK
frequency of only 2 MHz, maximum.
Serial Port Timing
Serial Clock Frequency SCLK - - 2 MHz (Max)
If you increase your PIC frequency from 4 MHz to 25 MHz, without
changing your setup_spi() statement, you will easily create an SCLK
signal for which the frequency is too high.
To fix this, you need to change the SPI clock divisor in the setup_spi()
statement. Look in the .h file for your PIC:
c:\program files\picc\devices\18f67j60.h
Look in this section of that file:
// Constants used in SETUP_SPI() are:
Then choose a new divisor constant that, when divided into 25 MHz,
will give you an SCLK of 2 MHz or less. Edit your setup_spi() statement
and put in the new clock divisor.
aaronik19
Design
PostPosted: Sat Jun 11, 2011 8:46 am     Reply with quote
Dear All, did you implemented the design on page 9 of the datasheet? Can you please send me the BOM because I did not find it.
Thanks in advance
aaronik19
PostPosted: Thu Mar 14, 2013 8:22 am     Reply with quote
I am using the pic18f4550 with 20mhz cystal. Do. Need to connect the cpuclk pin on the cs5463(pin2) to the pic pin 13, altough i have the crystal to the PIC?
aaronik19
PostPosted: Thu Mar 14, 2013 9:11 am     Reply with quote
Dear All, I continued to work on this project. I made a test to read Temperature as PCM Programmer suggested but with this setup I am getting the value of FFFF7F96 on my hyperterminal. Can someone tell me what could be wrong?
#include <test.h>
//#include <18F4550.H>
#fuses HS,NOWDT,NOBROWNOUT,PUT,NOLVP
#use rs232(baud=9600,parity=N,xmit=PIN_D2,rcv=PIN_D3,bits=8)
#define CS     PIN_E2
#define RESET  PIN_C1
#define CS5463_CONFIG_REG  0
#define CS5463_TEMP_REG    19
// SPI modes
void CS5463_write_command(int8 command)
output_low(CS);
spi_write(command);
output_high(CS);
void CS5463_write_reg(int8 reg, int8 msb, int8 mid, int8 lsb)
output_low(CS);
spi_write((reg << 1) | 0x40);   // OR with Write bit
spi_write(msb);
spi_write(mid);
spi_write(lsb);
output_high(CS);
int32 CS5463_read_reg(int8 reg)
int8 msb, mid, lsb;
int32 retval;
output_low(CS);
spi_write(reg << 1);
msb = spi_read(0xff);
mid = spi_read(0xff);
lsb = spi_read(0xff);
output_high(CS);
retval = make32(0, msb, mid, lsb);
return(retval);
float temp32;
int8 temp8;
output_high(CS);
output_high(RESET);
delay_ms(100);  // CS5463 osc start-up time is 60 ms typ.
printf("\f");
   //temp8 = make8(temp32, 2);  // Get upper byte of temp32
   printf("Temp32 = %LX\r\n", temp32);
   delay_ms(5000);
PostPosted: Thu Mar 14, 2013 3:13 pm     Reply with quote
Did you buy a cs5463 evaluation board, or did you build your own board ?
If you bought the board, post a link to the website for it. If you built the
board, post the schematic on a free image hosting website, and post a
link to the schematic here.
aaronik19
PostPosted: Fri Mar 15, 2013 3:48 am     Reply with quote
YEs, I built the circuit provided by Microchip:
http://ww1.microchip.com/downloads/en/AppNotes/00220a.pdf
page aa and page 12. But I replaced the CS5460 with CS5463.
PostPosted: Fri Mar 15, 2013 9:43 am     Reply with quote
When you call make32 with 0 for the first parameter then your value in Hyperterminal should be starting with '00'. This not being the case points to a programming error.
I didn't test but see at least one major bug in your main() that you shouldn't be making with your experience. Try to save some dignity and spot it yourself.
Page 2 of 3
