12f629 program problem
wwwglro
PostPosted: Sat May 22, 2010 1:11 am     Reply with quote
Hello
It gives 12f629, two buttons, two LEDs.
As long as the first button is held down, both LEDs are lit. If the second button is pressed, second LED goes off for 10 seconds. If you release the first button, both LEDs go off..
The program works fine but...the problem is that when I make that timing of 10 seconds, the second LED lights very short from time to time instead of going off, and I do not know why ...
Here is the program:
#include <12f629.h>
#FUSES NOWDT,INTRC_IO, NOPUT, NOPROTECT, NOBROWNOUT, NOMCLR, NOCPD
long bec0=0; // variable for first button
long bec1=0; // ....for second button
long intr=0; // sistem interrupt variable
long sec=0; // secondes
int8 flag0=0; // led0 flag
int8 flag4=0; // led1 flag (buzer)
int8 flag4_temp=0; // disable timing flag
#int_rtcc
void clock_isr()
intr++;
if (intr>250)     //counts secondes
sec++;
intr=0;
if (INPUT(PIN_A0)==0) //variable for first button
bec0++;
if (INPUT(PIN_A1)==0) //variable for seconde button
bec1++;
//pin 0
if (bec0>4) //after 5 interrupts (20ms) the first button is certainly pressed
flag0=1; // ledul 0 ON
flag4=1; // ledul 1 ON (buzer)
//pin1(buzer)
if (bec1>4 && bec0>4) //after 5 interupts (20ms) second button is certainly pressed
flag4_temp=1; //activate timing
sec=0;
flag4=0;
if (!INPUT(PIN_A0)==0 && bec0>5) //first button released
flag0=0; //led0 OFF
flag4=0; //ledul1 OFF (buzer)
bec0=0; //button0 flag reset
sec=0;
flag4_temp=0; //timing flag reset
if (!INPUT(PIN_A1)==0 && bec1>5) //second button released
bec1=0; //first button flag reset
flag4=0; //led1 OFF
set_tris_a(0b000000011); //GP0, GP1 intrare GP2:GP5 iesiri
setup_comparator (NC_NC_NC_NC);
set_rtcc(6); //
setup_counters( RTCC_INTERNAL, RTCC_DIV_16 | RTCC_8_BIT);
enable_interrupts (INT_RTCC);
do
if(flag0==0) // stingere led0
output_low(PIN_A5);
if(flag0==1) // aprindere led1
output_high(PIN_A5);
if(flag4==0)
output_low(PIN_A4);
if(flag4_temp==1)
if (sec>10)
flag4=1;
flag4=0;
if(flag4==1)
output_high(PIN_A4);
} while(1);
wwwglro
PostPosted: Sun May 23, 2010 1:16 am     Reply with quote
After simulations made with Proteus, I found that those small flickers of the second LED are completely random compared to the seconds counted in the ISR.
Is correct besides counting seconds, to test if the buttons are pressed and do other stuff, in the ISR function?
Thank you
P.S. Is correct to initialize just once rtcc in main (ex: set_rtcc(6)) ?
vinniewryan
PostPosted: Sun May 23, 2010 1:41 am     Reply with quote
Can you check the output of that pin with a scope? Do you have all required pulldown/pulldown resistors connected? Is your clock configured correctly?
These are the obvious fixes, I don't have time at the moment to go over your entire code, it seems like a lot for a couple of LED's.
Vinnie Ryan
