pipec
| PORTB Interrupt |
Posted: Fri May 21, 2010 3:10 pm |
Hi!
I am new in programming PIC in C, but maybe my code will be usefull.
I have tested it with proteus. If you like to make interrupt both edge (H2L and L2H) just take off the variable "d". I hope you like it.
#include <16F877.h>
#include "F:\progik\Programozás\PIC\saját_c\Interrupt\PIC16F877_registers.h"
BYTE blink = 0;
byte c,d;
#int_rb
void button_isr() {
c=portb;
d=~d;
if (d!=0){
if (!blink)
blink=1;
blink=0;
clear_interrupt(INT_RB);
enable_interrupts(INT_RB);
d=0;
trisd=0x00;
portd=0x00;
do {
if(blink){
output_high(PIN_D1);
output_low(PIN_D1);
} while (TRUE);
