Port D as Input problem
FCP
PostPosted: Wed May 19, 2010 6:30 pm     Reply with quote
I need help seting up the port D as an input for a PIC18F44J11. I have configure the port with the following code:
#use FAST_IO(D)
#byte PORTD = 0xf83
set_tris_d(ALL_IN);
port_d_pullups(TRUE);
it compiles without any trouble, but when I try to read the port I do not get the value that setup in the pins.
Thank you.
PostPosted: Wed May 19, 2010 6:59 pm     Reply with quote
1. How are you setting up the value on the pins ? What external circuits
provide the values ? What are the voltage levels on the pins ?
2. How are you testing this ? How do you know it fails ?
3. Post a short but complete test program (that is compilable)
that demonstrates the problem.
4. Is this a Proteus project ? Or is done on a hardware board ?
5. What is your CCS compiler version ?
FCP
PostPosted: Thu May 20, 2010 8:18 am     Reply with quote
It has a 8 bit DIP switch connected to the port, one side to ground and the other to the port pins, no other hardware.
I have tested several options, but the most conclusive ones are a) checking the contents of the PORTD and LATD register with the debugger (PCWH compiler from CCS), b) comparing the value of the read and branching to a different location if it matches (the circuit has two different LED's that light according to the branch.
#include "18f44j11.h"
#FUSES HS, WDT, PROTECT, DSBOR, WDT2048
#ZERO_RAM
#use DELAY(CLOCK=7372800)
#use FAST_IO(A)
#use FAST_IO(B)
#use FAST_IO(C)
#use FAST_IO(D)
#byte PORTA = 0xf80 // Port addresses
#byte PORTB = 0xf81
#byte PORTC = 0xf82
#byte PORTD = 0xf83
#define ALL_OUT 0x00
#define ALL_IN 0xff
#define COMM_LED PIN_A0
#define CTB_LED PIN_A1
#define DATA PIN_B0
#define CLOCK PIN_B1
#define UPDATE PIN_B2
#define CLEAR PIN_B3
#define MODE PIN_B4
#define SENSE PIN_B5
void main(void) {
unsigned int8 address;
int i ;
setup_port_a(NO_ANALOGS); //no analog inputs
set_tris_a(ALL_OUT); //all outputs
set_tris_b(0x60); //XERR input; rest outputs
set_tris_c(0x84); //RX, TARGET inputs; rest outputs
set_tris_d(ALL_IN);
output_low(CTB_LED);
output_low(COMM_LED);
output_low(DATA);
output_low(CLOCK);
output_low(UPDATE);
output_low(MODE);
address = ~PORTD;
if(address > 0x7f) {
output_high(CTB_LED);
else {
output_high(COMM_LED);
It is a hardware board, and other than not reading port D, everything else is working.
4.107
Wayne_
PostPosted: Thu May 20, 2010 8:45 am     Reply with quote
Your problem (other than not using code tags) may well be that as soon as you have read the port and turned on the output the pic goes to sleep and turns it off again Smile
address = ~PORTD;
else {
Put
while(true);
at the end to stop it from going to sleep.
better still, encase the main routine around a loop
while(true)
  address = ~PORTD;
  else {
    output_lowCTB_LED);
FCP
PostPosted: Thu May 20, 2010 9:24 am     Reply with quote
I made the follwing changes to the code, but the result was still the same, Not able to read port D.
#include "18f44j11.h"                        // CPU definitions, must be followed by...
//#device *=16                                 // ...enable 16-bit (!) data pointers
#FUSES HS, WDT, PROTECT, DSBOR, WDT2048      // PIC fuse settings
#ZERO_RAM                                    // Wipe RAM for safety
#use DELAY(CLOCK=7372800)                    // CPU clock frequency 7.3728 MHz
/* IO configuration                                                         */
#use FAST_IO(A)
#use FAST_IO(B)
#use FAST_IO(C)
#use FAST_IO(D)
/* Port definitions                                                         */
#byte PORTB = 0xf81
#byte PORTC = 0xf82
#byte PORTD = 0xf83
#byte RPOR6 = 0xecc                          // Peripheral pin selection (CLEAR)
#define ALL_OUT 0x00                         // All output TRIS value
#define ALL_IN  0xff                         // All input TRIS value
#define DATA PIN_B0
#define MODE PIN_B4
/* Data type definitions                                                    */
#define BOOL short
#define OFF 0
#define ON 1
/* Main program routine                                                     */
void main(void) {
    int i;
    set_tris_d(ALL_IN);
    setup_ccp1(CCP_PWM);
    setup_timer_2(T2_DIV_BY_16, 255, 15);
    RPOR6 = 14;
    set_pwm1_duty(8);
    output_low(CTB_LED);                     //switch off the controller timer bit LED
    output_low(COMM_LED);                    //switch off communication LED
    output_low(DATA);
    output_low(CLOCK);
    output_low(UPDATE);
    output_low(MODE);
   while(TRUE) {
      address = ~PORTD;
      else {
      restart_wdt();
Thank you.
FCP
PostPosted: Thu May 20, 2010 10:00 am     Reply with quote
BTW, I have five samples of the hardware and all behave the same way.
PostPosted: Thu May 20, 2010 2:47 pm     Reply with quote
4.107
I tried to compile your latest code with vs. 4.107 and I get this error:
*** Error 12 "PCH_Test.c" Line 56(20,21): Undefined identifier -- port_d_pullups
So how can you test this program if it doesn't compile ?
FCP
PostPosted: Thu May 20, 2010 3:05 pm     Reply with quote
In the CCS compiler go to "Tools", "Device Editor", select PIC18F44J11 in the "MCU Part" list. Then go to "Other Features", and from the drop-down list of "Pullups" select B,D,E.
PostPosted: Thu May 20, 2010 3:21 pm     Reply with quote
I don't have that version of the compiler. I only have the command line
version.
Since you added this feature to the compiler, how do we know that it's
generating the correct ASM code to do it ?
Compile this little test program and post the .LST file code that it
generates. Make sure the .LST file is in "CCS format", so it shows
the numerical register addresses. Don't use "Symbolic" format.
#include <18F44J11.h>
#Fuses HS, NOWDT, NOPROTECT
#use delay(clock=7372800)
#use FAST_IO(D)
#byte PORTD = 0xf83
#define ALL_IN  0xff
int8 address;
set_tris_d(ALL_IN);
address = ~PORTD;
FCP
PostPosted: Thu May 20, 2010 3:50 pm     Reply with quote
Here it is:
CCS PCH C Compiler, Version 4.107, 52671               20-May-10 14:40
               Filename: C:\FelixC\Projects\VMS Parking\Sensors\Ultrasonic\Wired\Port D Test2.lst
               ROM used: 50 bytes (0%)
                         Largest free fragment is 16326
               RAM used: 5 (0%) at main() level
                         5 (0%) worst case
               Stack:    0 locations
0000:  GOTO   0004
.................... #include "18f44j11.h"                        // CPU definitions, must be followed by...
.................... //////// Standard Header file for the PIC18F44J11 device ////////////////
.................... #device PIC18F44J11
.................... #list
.................... #FUSES HS, NOWDT, NOPROTECT                  // PIC fuse settings
.................... #use DELAY(CLOCK=7372800)                    // CPU clock frequency 7.3728 MHz
.................... #use FAST_IO(D)
.................... #byte PORTD = 0xf83
.................... #define ALL_IN  0xff                         // All input TRIS value
.................... /* Main program routine                                                     */
.................... void main(void) {
0004:  CLRF   FF8
0006:  BCF    FD0.7
0008:  CLRF   FEA
000A:  CLRF   FE9
000C:  MOVLW  FF
000E:  MOVLB  F
0010:  MOVWF  x48
0012:  BCF    FC2.6
0014:  BCF    FC2.7
0016:  MOVF   x49,W
0018:  ANDLW  E0
001A:  IORLW  1F
001C:  MOVWF  x49
001E:  CLRF   FD2
0020:  CLRF   FD1
....................    unsigned int8 address;
....................    set_tris_d(ALL_IN);
0022:  MOVLW  FF
0024:  MOVWF  F95
....................    port_d_pullups(TRUE);
0026:  BSF    F86.7
....................    address = ~PORTD;
0028:  MOVFF  F83,05
002C:  COMF   05,F
....................    while(1);
002E:  BRA    002E
0030:  SLEEP
Configuration Fuses:
   Word  1: F4A0   NODEBUG NOXINST STVREN NOWDT NOPROTECT CPUDIV6
   Word  2: FFDC   HS WDT32768 FCMEN IESO PRIMARY NOLPT1OSC T1DIG
   Word  3: F9FF   IOL1WAY MSSPMSK7 DSWDT2147483648 DSWDT DSBOR RTCOSC_T1 DSWDTOSC_INT
   Word  4: F1CF   NOWPCFG WPBEG WPDIS WPFP
PostPosted: Thu May 20, 2010 4:01 pm     Reply with quote
0026: BSF F86.7
As I suspected, this address is incorrect. The RDPU pull-up bit is in the
PortE register, and it's address is 0xF84. The compiler is using the wrong
register address.
To fix this problem, go back into the Device Editor and undo the changes
that you did. Disable PortD pullups. Then add the lines shown in bold
below to your program. Now the port_d_pullups() function will work.
#use FAST_IO(D)
#byte PORTD = 0xf83
#define ALL_IN 0xff
#byte PORTE = 0xF84
#bit RDPU = PORTE.7
#define port_d_pullups(x) RDPU=x
int8 address;
set_tris_d(ALL_IN);
address = ~PORTD;
FCP
PostPosted: Thu May 20, 2010 4:17 pm     Reply with quote
Now is working, thank you PCM programmer.
I hope CCS is monitoring the forum and will fix the entry for the corresponding IC.
PostPosted: Thu May 20, 2010 4:21 pm     Reply with quote
They don't. You can write a detailed email report to them.
1. Tell them the PIC, 18F44J11 and your compiler version.
2. Explain how you had to add port_d_pullups() using the Device Editor,
when it should be already supported.
3. Explain how when you did add it, the compiler used the wrong register
address.
If you don't want to email them, let me know and I'll do it.
FCP
PostPosted: Thu May 20, 2010 4:23 pm     Reply with quote
I will send them an e-mail, and once again, thank you.
