A numeric expression must appear here
feitanx
PostPosted: Thu May 20, 2010 8:10 am     Reply with quote
Why keep getting "numeric expression must appear" ?
#include <16F877A.h>
#device *=16 ADC=8
#fuses XT,NOLVP,NOWDT,NOPROTECT,NOPUT
#use rs232(uart1,baud=9600,xmit=PIN_C6,rcv=PIN_C7,stop=1,parity=N,bits=8)
#use fast_io(D)
int16 V1;
set_tris_d(0x00); // d all output
setup_adc(ADC_CLOCK_DIV_64);
setup_adc_ports(RA0_ANALOG);
for(;;)
set_adc_channel(0);
read_adc(adc_start_only);
V1=read_adc(ADC_START_ONLY);
output_d(V1);
Wayne_
PostPosted: Thu May 20, 2010 8:54 am     Reply with quote
Where ?
Please post the full compiler error.
I also think this : V1=read_adc(ADC_START_ONLY); should be
V1=read_adc(ADC_READ_ONLY);
And you need a delay, sleep or loop to check the completion flag between the start and a read of the ADC.
rnielsen
PostPosted: Thu May 20, 2010 3:32 pm     Reply with quote
I'm not sure if this is the issue but, you have defined V1 as int16 yet you are trying to output it to an 8bit port. Not sure if the compiler is complaining about that.
Ronald
Gabriel
PostPosted: Thu May 20, 2010 4:00 pm     Reply with quote
set_adc_channel(0);
why do you call read_adc(); twice with no delay in between and the first time you don't save the value?
.... off the top of my head... but to me that looks weird. might want to take a look at it.
g.
CCS PCM 5.078 & CCS PCH 5.093
PostPosted: Fri May 21, 2010 6:56 am     Reply with quote
The error is caused by the read_adc function not returning a value when you provide it with the parameter ADC_START_ONLY.
Change to:
These two lines are the same as the shorter and easier to read:
V1=read_adc();
Wayne_
PostPosted: Fri May 21, 2010 7:04 am     Reply with quote
Because you have a 1 second delay in your routine you could improve the performance by:-
set_adc_channel(0);
delay_ms(10);
for(;;)
  output_d(V1);
There is no need to keep calling set_adc_channel(0); as you are only using 1 channel.
Using V1=read_adc(); is good but it does the start and then waits for it to finish and does a read. During this time you could have done something else. It would have been better if they made it do a READ and then a START and still leave the delay up to you!
feitanx
PostPosted: Sat May 22, 2010 4:13 am     Reply with quote
What if I use multiple channel?
Wayne_
PostPosted: Mon May 24, 2010 2:58 am     Reply with quote
Then you will need to switch channels within your loop.
Now, depending on how fast your loop runs, what your sampling rate needs to be and how long it takes I would proberbly do the following:-
int8 state = 0;
set_adc_channel(0);
delay_ms(10);
for(;;)
  switch(chan)
  case 0:
    V0 = read_adc(ADC_READ_ONLY);
    set_adc_channel(1);
    chan++;
  case 1:
    V1 = read_adc(ADC_READ_ONLY);
    set_adc_channel(0);
    chan = 0;
  output_d(V1);
or something like that
