Initialize integer array in structure
c_user
PostPosted: Wed May 19, 2010 4:04 pm     Reply with quote
I have a simple struct as follows:
typedef struct
            int8 val[8];
            int8 type;
         } init_struct;
init_struct  init_example;
Then I try to initialize array, val, as follows:
   init_example.val = {1,2,3,4,5,6,7};
   init_example.type = 6;
When I compile, I get the following error messages for init_example.val line:
A numeric expression must appear here
Expect ;
Can anyone tell me what I am doing wrong?
c_user
PostPosted: Wed May 19, 2010 4:19 pm     Reply with quote
I am using version 4.109. Also the following (with brackets) gives the same error:
   init_example.val[] = {1,2,3,4,5,6,7};
PostPosted: Wed May 19, 2010 4:27 pm     Reply with quote
The versions page says the lastest version is 4.107:
http://www.ccsinfo.com/devices.php?page=versioninfo
If you want to initialize the structure, you can do it in the same statement
where you declare the structure. Example:
typedef struct
int8 val[8];
int8 type;
}init_struct;
init_struct init_example = {{1,2,3,4,5,6,7,8}, 9};
This fills the array and the 'type' variable.
c_user
PostPosted: Wed May 19, 2010 4:33 pm     Reply with quote
My mistake - I am using 4.107
There is a reason I need to initialize the array, in the way I am doing it. This is extracted code to present the problem.
Am I violating a syntactic rule of C?
PostPosted: Wed May 19, 2010 4:50 pm     Reply with quote
You can't use the comma-separated syntax to load an array at run-time.
c_user
PostPosted: Wed May 19, 2010 6:48 pm     Reply with quote
Thanks for identifying the problem.
