Help me with timer in PIC16F887
pk178
PostPosted: Tue May 18, 2010 12:41 am     Reply with quote
Hi everybody !
I want to control a DC motor. I use PWM module and timer 0 and timer 1 :
+ Timer 0 : Used to calculate timer.
+ Timer 1 : Used to read pulse from encoder to calculate speed of motor
(timer 2 was used to PWM module)
This is my code :
   SETUP_TIMER_1(T1_EXTERNAL|T1_DIV_BY_1);
   SETUP_TIMER_0(T0_INTERNAL|T0_DIV_1);
But only timer 0 work, timer 1 doesn't work. (Value of timers is display on PC screen)
When I change code to :
   SETUP_TIMER_1(T1_INTERNAL|T1_DIV_BY_1);
   SETUP_TIMER_0(T0_EXTERNAL|T0_DIV_1);
In this case, only timer 1 work, timer 0 doesn't work.
If I change this code to :
Both timer 0 and timer 1 work.
I don't know why. Please help me ! Thanks a lot !
PostPosted: Tue May 18, 2010 12:48 pm     Reply with quote
1. Are you testing this in Proteus ?
Sometimes Proteus won't work, depending upon the order of the lines
of code.
2. Are you using interrupts with either Timer0 or Timer1 ?
3. What is your compiler version ?
pk178
PostPosted: Wed May 19, 2010 6:33 am     Reply with quote
I solved this problem.
The problem is timer 0 overflow too fast, so encoder pulse can't increase. After that, I increase prescaler of timer 0 to 256 and it worked ok.
PostPosted: Wed May 19, 2010 12:22 pm     Reply with quote
That was one of my suspicions. That's why I asked in #2 if you were
using interrupts. It's similar to the problem in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=42222
