Custom LCD driver
takumi
Custom LCD driver
PostPosted: Mon May 17, 2010 11:44 pm     Reply with quote
Hello, hi all!
I try to used customize pin for 16x2 lcd but fail to use the different pin configuration.
Anyone can help please!
my code as follow:
/#define LCD_ENABLE_PIN PIN_B5
#define LCD_RS_PIN        PIN_B6
#define LCD_RW_PIN       PIN_B7
//#define LCD_DATA4         PIN_D0
//#define LCD_DATA5         PIN_D1
//#define LCD_DATA6         PIN_D2
//#define LCD_DATA7         PIN_D3
#define LCD_DATA_PORT D0_D1_D2_D3 // produce by wizard
#include <lcd.c>
   lcd_init();  // Always call this first.
      lcd_gotoxy(1,1);
      printf(lcd_putc,"Hello you");
      lcd_gotoxy(1,2);
      printf(lcd_putc,"PIC16F877A");
PostPosted: Tue May 18, 2010 1:22 pm     Reply with quote
Start by using the Flex lcd driver in the Code Library forum:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
It's easy to use, and it works for 99% of all people.
Once you have it working, then you can try to configure the CCS
driver with the Wizard, etc., if you still want to use it.
takumi
PostPosted: Tue May 18, 2010 8:11 pm     Reply with quote
tq it work
