PIC12F509 int16 and int8 counter code
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Mon May 17, 2010 9:33 am     Reply with quote
with tick defined as a int16 the compiler produces the following code:
....................          if (get_timer0()==0) tick++;
0095:  MOVF   01,W
0096:  BTFSS  03.2
0097:  GOTO   09B
0098:  INCF   0F,F
0099:  BTFSC  03.2
009A:  INCF   10,F
....................          if (tick > 270) {
009B:  MOVLW  00
009C:  MOVWF  07
009D:  MOVF   10,W
009E:  SUBWF  07,W
009F:  BTFSC  03.0
00A0:  GOTO   0B1
00A1:  XORLW  FF
00A2:  BTFSS  03.2
00A3:  GOTO   0AA
00A4:  MOVLW  0E
00A5:  MOVWF  07
00A6:  MOVF   0F,W
00A7:  SUBWF  07,W
00A8:  BTFSC  03.0
00A9:  GOTO   0B1
....................             output_toggle(LED);
00AA:  BCF    0C.0
00AB:  MOVF   0C,W
00AC:  TRIS   6
00AD:  MOVLW  01
00AE:  XORWF  06,F
Looks OK. But doesn't work. With tick an int8 and the check as tick > 245 code works fine:
0093:  MOVF   01,W
0094:  BTFSC  03.2
0095:  INCF   0D,F
....................          if (tick > 245) {
0096:  MOVLW  F5
0097:  MOVWF  07
0098:  MOVF   0D,W
0099:  SUBWF  07,W
009A:  BTFSC  03.0
009B:  GOTO   0A2
009C:  BCF    0A.0
009D:  MOVF   0A,W
009E:  TRIS   6
009F:  MOVLW  01
00A0:  XORWF  06,F
What have a overlooked? (please!). WDT is disabled so processor is not resetting.
Will Reeve
PostPosted: Mon May 17, 2010 9:37 am     Reply with quote
I've just narrowed it down. With tick set to an int16 code works as expected with if (tick > 254) but change it to if (tick > 255) which should work with an int16, code breaks!
PostPosted: Mon May 17, 2010 12:13 pm     Reply with quote
What's your compiler version ? I only have vs. 4.073, which is the
version of the free PCB compiler that's bundled with MPLAB v8.46.
I made the following test program and stepped through the code in MPLAB
simulator and it does work. 'result' goes to 0x01 in the Watch Window.
#include <12F509.H>
#fuses INTRC,NOWDT
int8 result;
int16 tick;
result = FALSE;
tick = 300;
if(tick > 255)
   result = TRUE;
   result = FALSE;
Here's the .LST file for it. With the comparison to > 255, the compiler
can optimize the test so that it only checks to see if the MSB of 'tick' is
non-zero. If that's the case, then the test is true. You can see them do
that in the code below.
0002:  CLRF   04
.................... int8 result;
.................... int16 tick;
.................... result = FALSE;
0003:  CLRF   0D
.................... tick = 300;
0004:  MOVLW  01
0005:  MOVWF  0F
0006:  MOVLW  2C
0007:  MOVWF  0E
.................... if(tick > 255)
0008:  MOVLW  00
0009:  MOVWF  07    // Set scratch register to 0x00
000A:  MOVF   0F,W  // Get MSB of 'tick' into W
000B:  SUBWF  07,W  // Compare MSB of 'tick' to 0x00
000C:  BTFSC  03.0  // Jump if a borrow occurred (ie., if MSB != 0)
000D:  GOTO   011
....................    result = TRUE;
000E:  MOVLW  01   // If MSB is != 0, then set 'result' = 01 (True)
000F:  MOVWF  0D
.................... else
0010:  GOTO   012
0011:  CLRF   0D
.................... while(1);
0012:  GOTO   012
Will Reeve
PostPosted: Mon May 17, 2010 12:52 pm     Reply with quote
Mine is version 4.107. Thanks. I've got your code to work (I am using real hardware and an LED as I don't use Mplab, your result variable I changed to a PIN!). I've gone back to the original code and mysteriously the code now works! I don't know why but I am happy! Finger trouble I used to say! I did think I was going insane!
Thanks for you help.
I hadn't realised MPLAB has a simulator....this has turned out to be a good question and answer as I haven't used MPLAB for maybe 10 years! Time to have another look I think as I usually ICD most code development but on these little parts you can't.
PostPosted: Mon May 17, 2010 3:51 pm     Reply with quote
The Simulator in MPLAB is great! Too bad you didn't know about this feature as it could have saved you a lot of time.
I often used the included stopwatch for timing measurements, much easier than pulsing an output pin connected to a scope.
