CCS PIC16F877A prototyping board schematic
louarnold
PostPosted: Thu May 13, 2010 8:49 pm     Reply with quote
This was probably asked before, but I can find no info:
I would like a schematic of the CCS PIC16F877A prototyping board. This board has the PIC16F877A ( a square chip) soldered onto the board, a stereo jack (3.5mm), a 9 V power input, RJ12 (6 conductor) jack, potentiometer and 3 LEDs (red, yellow, green).
I have a stereo to PC serial cable schematic, but I need to make something to go from my laptop (USB or teleco jack) to the stereo jack.
Lou.
PostPosted: Thu May 13, 2010 9:16 pm     Reply with quote
For your laptop, which doesn't have a DB-9 Com Port, you need to buy
a USB-to-Serial Adapter. Something like this:
http://www.siig.com/ViewProduct.aspx?pn=JU-CB1S12-S3
Some brands of this type of adapter sell for as little as $10 USD.
louarnold
PostPosted: Thu May 13, 2010 11:30 pm     Reply with quote
That's good. I assume there is some electronics in the cable, for the signal conversion?
Is a cable from the RJ12 telco jack to stereo plug also possible? any easier?
MikeP
PostPosted: Fri May 14, 2010 2:19 am     Reply with quote
The RJ12 connector is a programing port
http://www.ccsinfo.com/faq.php?page=icd_connection
Which works with this to program the chip
http://www.ccsinfo.com/product_info.php?products_id=icd_u64
louarnold
PostPosted: Fri May 14, 2010 8:46 am     Reply with quote
Thanks for the reference to the RJ12 port, but it's not really what I wanted.
Let me rephrase: My laptop has a phone jack (I assume RJ12). I was asking if I could connect from there to the stereo jack on the prototype board. The laptop runs Vista.
And I guess I still need the schematic for the board itself. The school only bought the board for us as individuals and not the software that would have the schematic (as I understand it). Can someone give me an alternate source?
PostPosted: Fri May 14, 2010 9:31 am     Reply with quote
I think this is the Software prototyping board.
If so, the 3.5mm jacks, implement serial ports, which can't connect to the 3.5mm jack on your laptop. They will (with the right wiring), attach to the USB-serial adapters, already pointed out by PCM programmer.
Just because things use the same connector, does not make them compatible.
SherpaDoug
PostPosted: Fri May 14, 2010 10:27 am     Reply with quote
A laptop is likely to have two types of rectangular "phone" style jacks. A wider one is for Ethernet. A narrower one is for a POTS telephone modem. Neither one is going to interface with your prototyping board. You need RS232 which is going to come from either a DB9 connector on the laptop, or a USB connector with a USB to RS232 adapter.
louarnold
PostPosted: Sat May 15, 2010 12:06 am     Reply with quote
Haha. well put. The telco jack on the laptop is likely used by an internal modem. I just never used it so far. The 3.5 mm jacks are for audio. Its the 3.5mm to usb RS232 adapter that I need,
louarnold
PostPosted: Sat May 15, 2010 12:12 am     Reply with quote
Yep. You are right. See my post to Ttelmah.
So... Anyone got a schematic for the adapter?
And then the schematic for the PIC16F877A prototyping board?
