get data from LCD problem
project2010
PostPosted: Thu May 13, 2010 2:41 pm     Reply with quote
i can use the lcd_getc function,but
if i want a 2 digit data, how can i get it?
(using the Flexible LCD driver for 20x4 LCDs)
for example
123456789 < 1 in lcdxy (1,1)
i would like to get 12 , 34 ,56 , 78 into
int8 A1,
int8 A2,
int8 A3,
int8 A4,
A1 = lcd_getc(1,1); <how can i keep get data?
A2 = lcd_getc(3,1);
thank you,
Embarassed
PostPosted: Thu May 13, 2010 3:05 pm     Reply with quote
Since your program wrote the data to the LCD, you should already
know what the data is. You should not have to read it from the LCD.
But, you need to read the data into a 3-byte array. The last byte of
the array must be set to 0x00. Then use atoi() to convert the numeric
string to an integer.
project2010
PostPosted: Thu May 13, 2010 11:58 pm     Reply with quote
Actually, I'm using the keypad to input some number, and store it.
Use for set the time on DS1307.....so need 2 digits stored in one number....
Confused
PostPosted: Fri May 14, 2010 10:45 am     Reply with quote
See this thread. It goes over the same problem you have: How to
convert two ASCII numbers from a keypad into one integer, and put
it in a variable.
http://www.ccsinfo.com/forum/viewtopic.php?t=42188
project2010
PostPosted: Sat May 15, 2010 2:46 pm     Reply with quote
#include<18F4620.h>            //include 18F4620 ports
#device adc=10
#fuses HS,NOWDT,PUT,NOPROTECT,NOLVP,NODEBUG
#use delay(clock=20000000)         //use 20MHz crystal
#include <LCD20x4.c>
#include <KBD.c>
#include <ds1307.c>
#include <stdlib.h>
char abc[2];
int x;
   lcd_init();
   while(true)
         abc[0]=2;
         abc[1]=5;
         abc[2]=0x00;
         x=atoi(abc);
         printf(lcd_putc,"\%u",x);
i have try some pattern....but it doesn't work
keep display 0.......... Sad
PostPosted: Sat May 15, 2010 3:03 pm     Reply with quote
abc, is too small. You have allocated two storage locations, and are then addressing three locations....
PostPosted: Sat May 15, 2010 4:48 pm     Reply with quote
Also, you are not loading the array with ASCII values. The atoi() function
expects an ASCII string. In C, to tell the compiler that a number should
be encoded in ASCII, you should put single quotes around the number.
Example:
abc[0] = '2';
However, don't put quotes around the final 0x00. It must actually be
a binary 0. Keep it the same as shown in your post.
project2010
PostPosted: Sun May 16, 2010 11:33 am     Reply with quote
#device adc=10
#include <KBD.c>
#include <ds1307.c>
#include <stdlib.h>
int a;
char abc[10];
int x;
   lcd_init();
   while(true)
         int a=8;
         abc[0]='2';
         abc[1]='5';
         x=atoi(abc);
it work it can display 25
but how can i put "int a" into "abc[0]"?
abc[0]="%d",a;
that's does not work ,result become 0
Also is atoi max support 0-255 right?
PostPosted: Sun May 16, 2010 11:46 am     Reply with quote
1. You ignored Ttelmah's post completely, in which he told you to
increase the size of the abc array.
2. You ignored my example of using single quotes, and changed it to
use double quotes.
Someone else can help on this thread.
project2010
PostPosted: Sun May 16, 2010 12:18 pm     Reply with quote
use double quotes.
sorry, i forgot to update the code....
i have read the reply for all guy...Wink
abc[10] increased, use single ' ' < but look like same.
