bright_krom
Char[] Array Problem |
Posted: Tue May 11, 2010 3:57 pm |
Hi everyone,
I wanna ask something;
Code: | char *x;
x="Hello"; | or Code: | char x[10];
x="Hello"; |
These codes are not loading a string to x, how can I do? Help please.
Thanks. |
Gabriel
Posted: Tue May 11, 2010 4:01 pm |
char x[5] = {'h','e','l','l','o'};
.... if i remember right.. that should do it....
Gabriel. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Posted: Tue May 11, 2010 4:33 pm |
You can initialize it when you declare the array. Example:
Code: | char x[6] = "Hello"; |
Or, you can load the array at runtime, by using strcpy:
char x[6];
strcpy(x, "Hello");
bright_krom
Posted: Wed May 12, 2010 5:00 am |
Thank you Gabriel and PCM. |
