16f877 pwm code problem
Neo
PostPosted: Thu May 06, 2010 4:08 pm     Reply with quote
Hi, I am trying to make 100khz pwm signal with 20 MHz oscillator, and I'll change duty with buttons...
I use this calculation : Tpwm=Tosc*4*(PR2+1)*1 => PR2=49
#include <16f877.h>
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#use delay (clock=20MHz)
#use fast_io(a)
#use fast_io(c)
int i=49;      //duty
void main ( )
   setup_psp(PSP_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   set_tris_a(0x03);
   set_tris_c(0x00);
   setup_ccp1(CCP_PWM);
   setup_ccp2(CCP_PWM);
   setup_timer_2(T2_DIV_BY_1,49,1);
   set_pwm1_duty(i);
   set_pwm2_duty(i);
   while(1) // in this loop making duty
      if (input(pin_a0))
         delay_ms(20);
         while(input(pin_a0)); //increase duty
         i+=3;
         if (i>49)
            i=49;
         set_pwm1_duty(i);
         set_pwm2_duty(i);
      if (input(pin_a1))
         delay_ms(20);
         while(input(pin_a1));
         i-=3;                      //decrease duty
         if (i<10)
            i=10;
         set_pwm1_duty(i);
         set_pwm2_duty(i);
Using this code in Proteus, but I can't reach 100khz frequency.
http://i41.tinypic.com/oj32ft.png (proteus)
Where is problem?
PostPosted: Fri May 07, 2010 3:21 am     Reply with quote
Have you told Proteus that your master oscillator is 20MHz?. I'd suspect this has not imported from the crystal properly. If I remember, setting the 'freq' value, does not automatically tell the simulator that this is the frequency in use....
Though I have Proteus, I don't use it's simulation. More trouble than it is worth.
Neo
PostPosted: Fri May 07, 2010 4:44 am     Reply with quote
In Proteus, if I change processors clock time to 20 MHz it works fine (Proteus gives 1mhz), but in reality where I can change processors clock time ?
I think I should tell this processor in program code.
I found something for pic18f2320 changing oscillator time with this code:
setup_oscillator(OSC_8MHZ)
I know 16f877 don't have internal oscillator, but what does it mean in Proteus "processors clock time"?
PostPosted: Fri May 07, 2010 8:46 am     Reply with quote
The way you change the processors frequency, is with the crystal....
Some processors, have _internal_ calibrated RC oscillators (not accurate enough for many applications), and these can then be controlled with the setup_oscillator instruction, _if selected in the fuses first_.
Your chip does not have this.
You cannot tell Proteus what the clock rate is, from Program code.
Your program code has to be told what the real oscillator is, just as Proteus does. This is what the clock statement does in CCS.
sshahryiar
PWM Problem Reply.
PostPosted: Sat May 08, 2010 3:29 am     Reply with quote
Firstly your code has got some problems. I will tell u later......Secondly, Proteus does not show PWM operations in a "should be" way......It made me remember I had a problem like u....
https://www.facebook.com/MicroArena
SShahryiar
sshahryiar
PostPosted: Sat May 08, 2010 3:34 am     Reply with quote
#include <16f877.h>
int i=49;      //duty
void main ( )
   setup_adc(ADC_OFF);
   set_tris_a(0x03);
   set_tris_c(0x00);
      if (input(pin_a0))
         delay_ms(20);
         i+=3;
         if (i>49)
            i=49;
      else if (input(pin_a1))
         delay_ms(20);
         if (i<10)
            i=10;
         set_pwm1_duty(i);
         set_pwm2_duty(i);
Try this code Neo. Hopefully it will do good.
SShahryiar
Neo
PostPosted: Sun May 09, 2010 1:26 pm     Reply with quote
Thank you sshahryiar but your code gived same result...
I'll try my code tomorrow in laboratory.
PostPosted: Sun May 09, 2010 2:17 pm     Reply with quote
Try this program. It will go from 0 to 100% duty cycle. It starts at 50%.
When you press 'F', it increases the duty cycle. When you press 'R' it
decreases the duty cycle. When you press 'S', it goes to 50%.
I tested this program in hardware with compiler vs. 4.107.
#include <16F877.h>
char c;
int8 pwm_duty;
setup_timer_2(T2_DIV_BY_1, 49, 1);
pwm_duty = 25;   // Initially set pwm duty cycle to 50%
set_pwm1_duty(pwm_duty);
   c = toupper(getc());   // Wait for input
   if(c == 'F')
      if(pwm_duty < 50)
         pwm_duty++;
   if(c == 'R')
      if(pwm_duty > 0)
         pwm_duty--;
   if(c == 'S')
      pwm_duty = 25;
Neo
PostPosted: Mon May 10, 2010 12:28 pm     Reply with quote
Thank you PCM programmer, but i tried my code today and it worked fine ;)
But i have new question, i want to get complemented pulse on other pwm out port. How can i turn first pulse to inverse?
PostPosted: Mon May 10, 2010 1:07 pm     Reply with quote
The 16F877 doesn't have the ability to do that. You need to use another
type of PIC.
It would help if you tell us what is the purpose of your project.
Neo
PostPosted: Mon May 10, 2010 1:40 pm     Reply with quote
I'm trying to make boost converter with Mosfet, and this control circuit dirves mosfet at 100kHz.
I asked that inverted pulse for my friend, he tries static compensation and need to drive 2 mosfets with complemented pwm.
