oxxyfx
LCD.C compile error |
Posted: Wed May 05, 2010 3:14 pm |
I am trying to interface a 18F2550 with a 2 line 8 character LCD screen. The LCD has a KS0066 controller on it.
Anyway I have the following pins connected:
RC0 = E
RC1 = R/W
RC2 = RS
D4 = RB3
D5 = RB2
D6 = RB1
D7 = RB0
These are defined as:
#define LCD_ENABLE_PIN PIN_C0
#define LCD_RS_PIN PIN_C2
#define LCD_RW_PIN PIN_C1
#define LCD_TYPE 1
#define LCD_DATA4 PIN_B3
#define LCD_DATA5 PIN_B2
#define LCD_DATA6 PIN_B1
#define LCD_DATA7 PIN_B0
#include <lcd.c>
The program is really nothing I just want to see if I can display something on the LCD:
setup_adc(ADC_OFF);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_31250|OSC_PLL_OFF);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
// TODO: USER CODE!!
lcd_putc("\fReady...\n");
while (TRUE) {
k=kbd_getc();
if(k!=0)
if(k=='*')
lcd_putc('\f');
lcd_putc(k);
Whenever I am trying to compile this code it comes back with an error on the LCD.c - Unidentified identifier:
Line 133:
#byte lcdlat = LCD_DATA_PORT+9
I am not sure what I am doing wrong. |
Posted: Wed May 05, 2010 3:59 pm |
Post a complete (but short) compilable program. Post the #include
for the PIC, #fuses, #use delay. Post all variable declarations.
For example, your code uses 'k' but is missing the declaration for it.
Post all #include lines, such as for kbd.c.
Also post your compiler version. |
oxxyfx
Posted: Wed May 05, 2010 5:55 pm |
Thank you, here is the H file:
#include <18F2550.h>
#device adc=8
#FUSES INTRC //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES PLL12 //Divide By 12(48MHz oscillator input)
#FUSES CPUDIV4 //System Clock by 4
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES VREGEN //USB voltage regulator enabled
#use delay(clock=8000000)
and here is the program:
#include "LCDTest.h"
#define LCD_TYPE 2
#include <lcd.c>
int k;
setup_adc(ADC_OFF);
setup_wdt(WDT_OFF);
setup_vref(FALSE);
while (TRUE) {
k=kbd_getc();
if(k!=0)
if(k=='*')
lcd_putc('\f');
lcd_putc(k);
The compiler version is 4.093 |
Posted: Wed May 05, 2010 6:16 pm |
Try adding the line in bold, so it's above the #include for lcd.c.
I didn't test this in hardware, but I think that's what it needs.
#define LCD_TYPE 2
#define LCD_DATA_PORT getenv("SFR:PORTB")
#include <lcd.c>
This is a problem in your version. They fixed it in later versions. |
oxxyfx
Posted: Wed May 05, 2010 7:00 pm |
Thank you, that almost fixed it. Now I am getting an error in the kbd.c:
Line 106:
case 0 : set_tris_kbd(ALL_PINS&~COL0);
unidentified identfier: set_tris_d |
oxxyfx
Posted: Wed May 05, 2010 7:02 pm |
#define use_portb_kbd TRUE
inserted in the code fixed the above error as well. Thank you. |
oxxyfx
Posted: Wed May 05, 2010 7:20 pm |
Now I only have to figure out why am I not seeing anything displayed on the LCD... |
oxxyfx
Posted: Thu May 06, 2010 1:39 pm |
Got it working. The code was ok, the contrast pin required different values for the resistors. Thanks again. |
