Help on CDC serial emulator and PIC18F46J50
alexandrecf80
PostPosted: Tue May 04, 2010 8:14 am     Reply with quote
I need an example code for CDC serial emulator on PIC18F46J50.
My code works great on PIC18F4550, but the device is not recognized when I compile for PIC18F46J50.
#include <18F4550.h>
//configure a 8MHz crystal to operate at 48MHz
#fuses PLL2,CPUDIV1,USBDIV,HSPLL,NOFCMEN,NOIESO,BROWNOUT,BORV20,VREGEN,NOWDT,WDT32768,MCLR,NOLPT1OSC,NOPBADEN,CCP2C1,STVREN,NOPROTECT,NOCPB,NOCPD,NOWRT,NOWRTC,WRTB,NOWRTD
#use delay(clock=48000000)
#include <usb_cdc.h>
int8 data,i=0;
   unsigned long int a;
   usb_cdc_init();
   usb_init();
   a=0;
   while(!usb_cdc_connected())
   do
       usb_task();
      output_low(PIN_D0);
      output_high(PIN_D0);
      if (usb_enumerated())
         if(usb_cdc_kbhit())
            data = usb_cdc_getc();
            output_low(PIN_D0);
            if(data == 0x00)
               usb_cdc_putc(0x00);
               usb_cdc_putc(0xFF);
            delay_ms(50);
   } while (TRUE);
Thanks,
Alexandre
