My UART setting can't receive data !! 24FJGB106
sindyme
PostPosted: Thu Apr 29, 2010 3:33 am     Reply with quote
CCS Ver : PCD 4.017
PIC : PIC24FJ256GB106
There is my code ~
I want to use "#pin_select" to setting PIC24FJ256GB106 PR pin
But It can't receiver any data.
The RDA_interrupt no work ~ How can I solve it ?
Please help me ~ thanks vary much Orz.
My #pin_select at H.file
PS : The xmit can work. It can send data to hyperterminal.
#int_RDA
RDA_isr()
   Temp = getc(coma);
   fprintf(coma,"%c",Temp);
   // for testing
#int_RDA2
RDA2_isr()
   Temp = getc(comb);
   fprintf(comb,"%c",Temp);
   // for testing
   setup_spi( FALSE );
   setup_spi2( FALSE );
   setup_wdt(WDT_OFF);
   setup_adc_ports(NO_ANALOGS);
   setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_RDA2);
   for(;;)
       //for testing
       fprintf(coma,"comb test work\r\n");
       fprintf(comb,"comb test work\r\n");
And my H.file
#FUSES ICSP2                    //ICD uses PGC2/PGD2 pins
#FUSES WINDIS                   //Watch Dog Timer in non-Window mode
#FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
#FUSES PR                       //Primary Oscillator
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO                  //OSC2 is clock output
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES IOL1WAY                  //Allows only one reconfiguration of peripheral pins
#FUSES WPEND_LOW
#FUSES NOWPCFG
#FUSES NOWPDIS
#FUSES PLL1                     //No PLL PreScaler
#FUSES DISUVREG
#use delay(clock=24000000)
#pin_select U1TX=PIN_G6
#pin_select U1RX=PIN_G7
#use rs232(baud=115200,parity=N,bits=8,stream=coma)
#pin_select U2TX=PIN_B14
#pin_select U2RX=PIN_B15
#use rs232(baud=115200,parity=N,bits=8,stream=comb)
PostPosted: Thu Apr 29, 2010 6:43 am     Reply with quote
Both use rs232 statement don't have a reference to a hardware UART, so they will create software UARTs. Consult
the manual, you need to add UART1 and UART2 keywords.
