		| Author | Message |
		| darren logan Guest
				| Optimising tricks of the trade ! |
				|  Posted: Sun Feb 02, 2003 5:53 am |   |
				| Hello,
 Im fairly new to PIC C, but have just completed my first project involving many of the more advanced features of a PIC (such as timer and UART interrupts).
 My budget was to used a PIC16F870 and several times during the project I was faced with the dreaded OUT OF ROM message.
 When this happened, I would go back through my code and check to see if I could cut down or optimise to trim down the code size, and sure enough I did.
 I learnt several tricks along the way to save space and Im sure it would be of benefit to share mine, and you share yours. Here are a couple that made a big difference for me...
 (Note that these may not apply to you, depending on your setup but I should imagine they will come in handy at some point!):
 Instead of using:
 output_low(whatever)
 Use:
 bit_clear(*x,y)
 (also use bit_set instead of output_high)
 Instead of using:
 delay_ms(xxx)
 Use:
 for(i=0;i
(I.e., use a for/loop. However a for loop instead of delay_us on the other hand does not save space)
 Please post your handy tips !
 Cheers,
 Darren
 ___________________________
 Original Post ID: 11198
		| mark r. hahn Guest
				| Re: Optimising tricks of the trade ! |
				|  Posted: Sun Feb 02, 2003 5:47 pm |   |
				| :=Hello, --- snip ---
 :=Please post your handy tips !
 :=Cheers,
 :=Darren
 I wrote a review of the CCS PCM compiler a few years back. I included several tips on how to make your programs smaller. Most of what I wrote then still holds. You might wish to check out my web page:  <a href="http://home.hvc.rr.com/mhahn/HahnTronix.html" TARGET="_blank">http://home.hvc.rr.com/mhahn/HahnTronix.html</a>
 Happy crunching,
 Mark Hahn
 Original Post ID: 11214
		| Darren Logan Guest
				|  Posted: Wed Feb 26, 2003 6:41 pm |   |
				| Hello,
 My program contained several write_eeprom and read_eeprom commands.
 I replaced them with my own read/writes thus:
 void writetoeeprom(int addr, int data) {
 write_eeprom(addr,data);
 int readfromeeprom(int addr) {
 return(read_eeprom(addr));
 This made a significant difference.
 Regards,
 Darren
 Original Post ID: 12149
 | You cannot post new topics in this forum You cannot reply to topics in this forum
