16F886 Port B interrupts
groberts
PostPosted: Thu Apr 22, 2010 10:54 pm     Reply with quote
I have been scanning the forum for something which matched my question but haven't seen anything. So here goes...
I have a momentary switch connected to the B0 pin. Using #INT_EXT I have had no problems servicing this interrupt. But the CCS manual is not clear about how to handle using interrupts on the other portB pins. I want to use B1 as another interrupt for a ack from another Pic. I understand that the int should be both edges and will manage that. But with V4.086, the management of interrupts on bits B1-3 is not clear. Must I clump them all within #INT_RB? How will that affect the #INT_EXT since this is using B0?
Based on the variables in the 16F88.h file I thought I would be able to use something specific like #INT_B1 or #INT_RB1. Those result in compile errors.
Is the only way to work this, through a single interrupt for the port B which has to determine which pin caused the interrupt?
Looking forward to your thoughts/help
GregR
PostPosted: Fri Apr 23, 2010 2:54 pm     Reply with quote
Here's a demo program that is a modification of the CCS Ex_pbutt.c
program. It demonstrates how to do PortB Interrupt-on-Change
interrupts and External interrupts in the same program.
It has Port B Interrupt-on-change interrupts on Pins B1 and B2,
and External interrupts on Pin B0. When you press a push-button
on any of those pins, you will get output on the Terminal window of
your PC, showing which button was pressed.
#include <16F886.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOLVP
short int dbutton0, dbutton1, dbutton2;
// This function reads Port B without changing the TRIS.
int8 input_state_b(void)
#byte PortB = getenv("SFR:PORTB")
return(PortB);
#int_ext
void int_ext_isr(void)
dbutton0 = TRUE;
delay_ms(1);   // Debounce delay for push-button switch
#define HIGHTOLOW  FALSE
#define LOWTOHIGH  TRUE
int8 current, last;
#int_rb
void int_rb_isr(void)
current = input_state_b();
#if LOWTOHIGH
   if ((!bit_test(last,1))&&(bit_test(current,1)))
       dbutton1 = TRUE;
   if ((!bit_test(last,2))&&(bit_test(current,2)))
       dbutton2 = TRUE;
#elif HIGHTOLOW
   if((!bit_test(current,1))&&(bit_test(last,1)))
       dbutton1 = TRUE;
   if((!bit_test(current,2))&&(bit_test(last,2)))
       dbutton2 = TRUE;
last = current;
delay_ms(1);
void init()
dbutton0=0;
dbutton1=0;
dbutton2=0;
last = current;
init();
port_b_pullups(0b00000111); // Enable pullups on PortB bits 0,1,2
delay_us(10);   // Allow time for pull-ups to initialize
enable_interrupts(INT_EXT_L2H);
enable_interrupts(INT_RB1);
enable_interrupts(INT_RB2);
input_state_b();   // Clear mismatch condition
clear_interrupt(INT_RB);
clear_interrupt(INT_EXT);
   if(dbutton0)
      putc('0');
      dbutton0 = FALSE;
   if(dbutton1)
      putc('1');
      dbutton1 = FALSE;
   if(dbutton2)
      putc('2');
      dbutton2 = FALSE;
