Can anyone interpret me about #use rs232(........)
sadism04
PostPosted: Thu Apr 22, 2010 2:46 pm     Reply with quote
#use rs232(baud=9600, xmit = PIN_C6, rcv = PIN_C7, parity = N, bits = 8)
#use rs232(uart1, baud = 19200, Enable = EPIN, stream = Remote, DISABLE_INTS)
#use rs232(DEBUGGER, baud = 19200, stream = Debug, DISABLE_INTS)
#use rs232(baud=38400, xmit=PIN_C6, rcv=PIN_C7, stream=PC, FORCE_SW)
I need to know what is all of parameters in rs232 mean ?
And if i want 2 PIC communicate through serial bus, what should I do ?
Could you tell me, plz .
PostPosted: Thu Apr 22, 2010 2:53 pm     Reply with quote
Download the CCS manual. The parameters are all explained in the
#use rs232 section:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
