how to measure the RPM
karthickiw
PostPosted: Wed Apr 21, 2010 9:26 am     Reply with quote
Hai CCS friends,
i want to measure accurate RMP value using PIC microcontroller. Now i am use timer1 to capture and count the signal from NPN type proximity sensor and Timer0 is calibrate the 1 seconds timer. every 1 second is finished, i multiple 60 into the count to get RPM. i have problem with reference time. In this method every one seconds only get RMP. There is any alternative method to measure the RMP.
01011
PostPosted: Wed Apr 21, 2010 10:41 am     Reply with quote
hi
i'm also reading a motor speed with a pic, but by using this method:
i calculate the period between to revolution of my motor;
#INT_TIMER0
void tmr0_isr()
    // motor period is bigger than max limit
    // Fm = period * X * Tc * RTCC_Div
    // RPM = F * 60
    //  -> X is encoder pulse per revolution (48)
    //  -> Tc is instruction time (0.25µs)
    period = 0xFFFF;
    tmr0_oveflow = 1;
/*#INT_EXT
void ext_isr()
    int16 t;
    t=get_timer0();
    if( tmr0_oveflow == 0)
        period = t;
    tmr0_oveflow = 0;
    set_timer0( 0 );
with this code, period is used to store information about the motor period, and can be translated in the real period
if tmr0_oveflow == 1, motor is too slow (rpm is too small)
is it ok?
karthickiw
thank you
PostPosted: Wed Apr 21, 2010 10:03 pm     Reply with quote
hai,
Thank you for your reply. I already done likewise, in this method every one second we get the RMP value. I need live RPM value without 1 second delay.
palomino
PostPosted: Wed Apr 21, 2010 10:38 pm     Reply with quote
Can you see on the example folder, (EX_FREQC.C). I think is a similar application, but just before print the "freq" variable multiply it by 60.
Regards.
Rafael
Mexico Wink
SherpaDoug
Re: thank you
PostPosted: Thu Apr 22, 2010 6:24 am     Reply with quote
If you get 1 countable edge per revolution and you measure once per second your RPM value will have a resolution of 60. If you measure 10 times per second your RPM will have a resolution of 600. Frequent results will cost you resolution. Getting multiple counting events per revolution , either with multiple sensor targets or by measuring period with a fast clock, will help.
01011
Re: thank you
PostPosted: Thu Apr 22, 2010 7:09 am     Reply with quote
karthickiw wrote:
hai,
in my code, you can calculate speed after every revolution (because you calculate the time between 2 revolutions)
by using an encoder of X pulse per revolution, you can even calculate speed X times/rev.
