Help to use external interrupt
alexerty
PostPosted: Mon Apr 19, 2010 1:32 am     Reply with quote
Hello:grin:
I post a new topic because I trying to validate my external interrupt program.
I have a function when my button RB0(INT0) to press that my LED (on RB1) can work.
It's a simple program just to validate external interrupt.
Unfortunately, when I simulate my program as Isis, it doesn't work.
This my code...
Main.h
#include <16F88.h>
#device adc=8
#FUSES INTRC_IO                 //Internal RC Osc
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#use delay(clock=8000000)
Main.c
#include "D:\projet c\main6.h"
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#use delay(internal=8M)
#int_EXT
void  EXT_isr(void)
output_toggle(PIN_B1);
clear_interrupt(INT_EXT);
#int_TIMER0
void  TIMER0_isr(void)
#int_TIMER2
void  TIMER2_isr(void)
   enable_interrupts(global);                 //GIE=1
   enable_interrupts(INT_EXT);               //INTE=1
   ext_int_edge(L_TO_H);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_128);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_16,156,16);
   setup_ccp1(CCP_OFF);
   setup_vref(FALSE);
   setup_oscillator(OSC_8MHZ|OSC_INTRC);
   // TODO: USER CODE!!
Could you help me please?
Charlie U
PostPosted: Mon Apr 19, 2010 10:23 am     Reply with quote
Start by adding: enable_interrupts(GLOBAL); following the existing enable_interrupts calls. You have enabled the individual interrupts, but not the global interrupt.
alexerty
PostPosted: Mon Apr 19, 2010 10:30 am     Reply with quote
if you look my code I put enable_interrupts(GLOBAL)
Charlie U
PostPosted: Mon Apr 19, 2010 11:02 am     Reply with quote
Oops.
I am used to enabling the individual interrupts then the global last. I overlooked the earlier call.
Sorry.
PostPosted: Mon Apr 19, 2010 12:17 pm     Reply with quote
Do you have a pull-up resistor on the External interrupt pin ?
You need one. Here is the circuit that you need:
           +5v
            > 4.7K
            <         ___ Push button switch
To          |        _|_|_
PIC -----------------o   o------
pin                            |
                              --- GND
alexerty
PostPosted: Tue Apr 20, 2010 3:06 am     Reply with quote
Thanks for your responses
I haven't a pull-up resistor on the External interrupt pin but a pull-down as I trig interruption from Low to high voltage (ext_int_edge(L_TO_H); )
                              Push button switch
To                                    _|_|_
PIC ----------------------------------o   o--------------------->+5v
pin            |
                > 4.7K
               --- GND
PostPosted: Tue Apr 20, 2010 1:42 pm     Reply with quote
Your program is too complicated. Look at the very simple program
that I have posted near the end of this thread. It tests #INT_EXT.
http://www.ccsinfo.com/forum/viewtopic.php?t=38804
alexerty
PostPosted: Wed Apr 21, 2010 5:13 am     Reply with quote
well I try with your code
#include <16F88.h>
#fuses INTRC_IO,NOWDT,BROWNOUT,PUT,NOLVP
#INT_EXT
void ext_isr(void)
[b]output_high(PIN_B1);  // Initially set Pin B1 high[/b]
But it doesn't work: B1 still on high state when I press button on RB0
I have tried also to linking /MCLR on 5V but it doesn't work either
thank you for your help again
[/img]
PostPosted: Wed Apr 21, 2010 5:24 am     Reply with quote
What happens if you reduce the program to just blinking the LED?
#include <16F88.h>
Also post your compiler version number.
alexerty
PostPosted: Wed Apr 21, 2010 6:51 am     Reply with quote
#include <16F88.h>
This program work perfectly .
I manage to do all interrupt timers (1,2,3) and convert analog
My only issue , this is external interruption Mad
I'm not at home
I'll give you my compiler version number as soon as I get home
alexerty
PostPosted: Wed Apr 21, 2010 10:57 am     Reply with quote
So the compiler version number is 4.038
PostPosted: Wed Apr 21, 2010 12:22 pm     Reply with quote
I installed vs. 4.038, and used the program you posted just above
the schematic. I used my switch schematic, because that's how
the PicDem2-Plus board is wired. It worked.
To make it work reliably in hardware, I had to add a small debounce
delay as shown below in bold. Normally we don't like to put delays in
an interrupt routine, but for this program it's OK.
#INT_EXT
void ext_isr(void)
delay_ms(10); // Debounce delay
Also, on the PicDem2-Plus board, I didn't use the on-board LEDs.
I added a separate LED with a series resistor on pin B1.
So, except for the switch wiring, it's very similar to your schematic.
alexerty
PostPosted: Thu Apr 22, 2010 2:53 am     Reply with quote
Thank PCM Programmer
I begin to wonder if the problem does not come from Isis which doesn't support external interruption.
There is no reason for not working here.
I will try to run your program on my personal card development.
alexerty
PostPosted: Fri Apr 23, 2010 4:14 pm     Reply with quote
So , it does work now
I have resolved my issue
The problem was a bug from Isis
You can close the topic if you want
Thank you for your help Very Happy
