16f628a HPWM
OzanGazi
16f628a HPWM
PostPosted: Tue Apr 20, 2010 5:43 am     Reply with quote
Hi all,
I cannot get pwm signal on pin_b3. Is this code wrong ??
#include <16f628a.h>
#use delay (clock=4000000)
#fuses intrc_io,Brownout,NOWDT,PROTECT,NOLVP,put,cpd,nomclr
setup_ccp1(CCP_PWM); // Configure CCP1 as a PWM
setup_timer_2(T2_DIV_BY_4, 127, 1);
set_tris_b(0);
while(true)
set_pwm1_duty(127);
delay_ms(20);
Abdulla M.A.
View user's profile Send private message Visit poster's website Yahoo Messenger
PostPosted: Tue Apr 20, 2010 6:55 am     Reply with quote
this is the program with duty cycle=50%
if you have any question, you can ask.
#fuses xt,nowdt,nocpd,noprotect,nolvp
set_tris_b(0x00);
setup_ccp1(ccp_pwm);
set_pwm1_duty(500); //50% duty cycle
setup_timer_2(t2_div_by_4,249,1);
Abdulla
"A scientist can discover a new star, but he cannot make one. He would have to ask an engineer to do that."
"For an optimist the glass is half full, for a pessimist it's half empty, and for an engineer is twice bigger than necessary."
OzanGazi
PostPosted: Tue Apr 20, 2010 7:15 am     Reply with quote
Ok it works Thank you...
But still there is a problem..
while(true)
if(++MotorPower>1000)
MotorPower=0;
delay_ms(2);
set_pwm1_duty(MotorPower);
PWM output works with %50 fixed duty ratio..But when i put this code in program PWM signal stops and pin_B3 stay on "0"..What do you say for this condition ??
Abdulla M.A.
PostPosted: Tue Apr 20, 2010 9:08 am     Reply with quote
welcome Wink
int16 MotorPower;
   set_tris_b(0x00);
   while(true)
         MotorPower=0;
Your program work fine!!!! I tested it now, so what the errors if there is??
Abdulla
