Help 18F4685 CAN bus
hithat
PostPosted: Fri Apr 16, 2010 11:43 am     Reply with quote
I'm working with pic18f4685 and I can't get CAN working! and I don't know what I'm doing wrong.
Can you help me? I just need a simple test (send and receive something).
Thanks.
Tiago
PostPosted: Fri Apr 16, 2010 12:29 pm     Reply with quote
Use the forum's search page. Search for
18F4685 CAN
Set it to: Search for All Terms
Then you find posts like this one:
PIC18F4685 - which CAN header? (which CCS driver file to use)
http://www.ccsinfo.com/forum/viewtopic.php?t=36676
The answer is: can-18F4580.c
This thread discusses your problem.
http://www.ccsinfo.com/forum/viewtopic.php?t=40898
He uses the code from this thread (but he modified it):
http://www.ccsinfo.com/forum/viewtopic.php?t=29627&start=7
Also search for this:
can-18F4580.c
You will find many threads which discuss how to use that driver file.
There are many topics on the forum about the CAN bus, and these
threads discuss all the likely problems that you will have. Please
read all these threads. This is a 3-page thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=40202
MikeW
PostPosted: Fri Apr 16, 2010 11:28 pm     Reply with quote
I am using a PIC18F4680, and it works fine using the CCS supplied routines.
Mike
hithat
PostPosted: Sat Apr 17, 2010 9:49 am     Reply with quote
I already read and search and everything that suppose to do i have done and nothing works. I have only 2 boards and one looks to be fine but i don't know because the other boards have a problem or i think that have. Because when i do can_init() the mode must be config and when exit the routine can_init() mode is put to mode normal but if i try to change to mode config again he stop in the while( (CANSTAT.opmode) != mode ); in routine can_set_mode.
Another thing that i try was enable CAN interrupts and when i try to send something it goes to CANIRX and CANERR interrupts, and this means that an error occur! Right? Sorry for my english:-(
I'm not using any resistance of 120 ohms the cable is about 20 inch. Is anything wrong? please help :-(
Mike
hithat
PostPosted: Sat Apr 17, 2010 10:16 am     Reply with quote
Mike
Hi Mike, did you change anything in ccs routines for your code work? Can you post here your code?
Many thanks.
PostPosted: Sat Apr 17, 2010 11:49 am     Reply with quote
You don't have it working in a basic program. Then you try an advanced program.
I suppose you also left off the CAN bus transceiver chips (MCP2551) ?
hithat
PostPosted: Sat Apr 17, 2010 12:20 pm     Reply with quote
I am an Electronic Eng. i know that i need to use a transceiver.
i test the 2 boards in CAN_OP_LOOPBACK mode, and they work fine. but if i change for normal mode they donĀ“t detect nothing in receiver buffers and they return sucsses in PUTD().
i have seen many code with this library of ccs "can-18F4580.c" and i am doing just the same.
some info:
- i dont use terminal resistor.
- conected rs terminal of mcp2551 to ground
- and the baud rate is define as default from ccs library "can-18F4580.c".
PostPosted: Sat Apr 17, 2010 1:44 pm     Reply with quote
The test program for two CAN bus boards that is shown in this
thread does work. It has been tested many times (not only by me):
The two boards should be connected as shown in this schematic:
http://www.microchip.com/forums/upfiles.aspx/52252/1E05A177D4B746B0B4C23DB18CC4F360.JPG
If you do it as shown in the two posts above, then it should work.
hithat
PostPosted: Sat Apr 17, 2010 6:31 pm     Reply with quote
I had already did that and nothing works... like I said it only works in loopback and it give me success in PUTD() functions but nothing appears on the other side. The only thing that miss me was the terminal resistor 120 ohms, but I know that for small test it suppose to work without... but we never sure :(
So I will work until this do what I want. So thanks very much for your help and time with me.
MikeW
PostPosted: Sun Apr 18, 2010 12:27 am     Reply with quote
I suggest you post your schematics, and how you are connecting the 2 boards.
For your information, this was my methodology :-
First, I purchased the excellent CCS CAN development system.
The CCS board has 4 CAN nodes, one can(sic) be used as a "sniffer", one as an output, one as an input.
So, I had the CCS system displaying LED data, responding to pushbutton presses, using the supplied CCS example software.
I then connected my own design board to the CCS one, and "sniffed" the data traffic on the bus generated by the CCS dev. system.
That proved that my CAN timing etc was corrrect (which was not simple).
After that I sent messages from my board to the CCS output nodes.
Voila !!, I was up and running.
Mike
