[Help] LCD.c and flex_lcd.c
8051topic
PostPosted: Fri Apr 16, 2010 10:10 am     Reply with quote
Hi everybody!
I'm using PIC16F887 and LCD 16x2.
I've problem: use flex_lcd.c is OK, but use lcd.c of CCS library the LCD display not right (#).
My code here:
#include <16F887.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
#use delay(clock = 4000000)
#include <lcd.c>
//#include "flex_lcd.c"
#define LCD_DATA4    PIN_D0
#define LCD_DATA5    PIN_D1
#define LCD_DATA6    PIN_D2
#define LCD_DATA7    PIN_D3
#define LCD_ENABLE_PIN   PIN_A1
#define LCD_RS_PIN   PIN_A3
#define LCD_RW_PIN   PIN_A2
   lcd_init();  // Always call this first.
      lcd_gotoxy(1,1);
      printf(lcd_putc,"Hello you");
      lcd_gotoxy(1,2);
      printf(lcd_putc,"PIC16F887");
I use internal crystal.
I did not edit #define in LCD.c file and CCS version is 4.105.
Thanks for all!
PostPosted: Fri Apr 16, 2010 11:02 am     Reply with quote
If a file looks for #define statements, you need to put them above
the #include statement for the file. Example:
#include <16F887.h>
#include <lcd.c>
8051topic
PostPosted: Sat Apr 17, 2010 6:07 am     Reply with quote
Thank you very much.
It's worked perfectly.
