Problem with ENC28J60 + PIC24FJ256GB110
microlo75
PostPosted: Fri Apr 16, 2010 3:54 am     Reply with quote
Hello everyone,
I have a problem, use a PIC24FJ256GB110 + ENC28J60
these examples work:
ex7a.c> OK
ex7b.c> OK
ex8a.c> OK
ex8b.c> OK
ex9a.c> OK
ex9b.c> OK
ex10a.c> OK
ex10b.c> OK
ex11.c -- ex17.c> NO !
I attach configurations...
Please help me javascript:emoticon('Embarassed')
Code deleted.  See:
c:\program files\picc\tcp-ip\pic examples source\ex11.c
Some code deleted.
Reason: Forum Rule #10:
10. Don't post the CCS example code or drivers
-- Forum Moderator
// ccstcpip.h
#define STACK_USE_CCS_PICENS   1 //18f4620 + enc28j60
#define STACK_USE_CCS_PICNET   0 //18f6722 + realtek
#define STACK_USE_CCS_PICEEC   0 //18f97j60
#if STACK_USE_CCS_PICENS
 #define STACK_USE_MCPENC 1
#endif
#if STACK_USE_CCS_PICEEC
 #define STACK_USE_MCPINC 1
#endif
#include <24FJ256GB110.h>
#DEVICE ADC=10
#TYPE  short=8, int=16, long=32
#fuses HS,PR_PLL,NOWDT,ICSP2
#fuses PLL5
#use delay(clock=32000000)
// IMPOSTAZIONI PER RS232
#use rs232(UART1, baud=9600, xmit=PIN_F5,rcv=PIN_F4)
// IMPOSTAZIONI PER SPI ENC28J60
#PIN_SELECT SDI1=PIN_D2
#PIN_SELECT SDO1=PIN_F8
#PIN_SELECT SCK1OUT=PIN_B1
#PIN_SELECT SS1OUT=PIN_D14
#use spi(SPI1, baud=1000000, MODE=0, MASTER, BITS=8)
#include "tcpip/stacktsk.c"    //include Microchip TCP/IP Stack
[Code deleted]
HARDWARE.H
Code deleted. See:
c:\program files\picc\tcp-ip\pic examples source\drivers\hardware.h
Embarassed Embarassed Embarassed
bkamen
PostPosted: Fri Apr 16, 2010 7:22 am     Reply with quote
yea, the stack doesn't work so well on PIC24.
I started to convert it and got dhcp working... but that was it.. (I think)
I might get back into it to check in a while.. I'd like to see it functioning for PIC24... but it doesn't do so well yet.
-Ben
microlo75
PostPosted: Fri Apr 16, 2010 7:33 am     Reply with quote
-Ben
????????? this is terrible news
if you can help me, I'd be very happy, I thought to incorporate the UDP communication without problems but instead ....
thanks for any help
bkamen
PostPosted: Fri Apr 16, 2010 9:01 am     Reply with quote
I would be glad to help (since it would help me too) but right now I have a couple projects I'm working on -- so I couldn't promise any sort of timeline.
If you wanted to get a working stack for that PIC, download the latest from Microchip (version 5.20b, by the way) and then use the free lite version of C30.
While working in CCS is very nice and preferrable, you'd at least get your project working for now while the stack is being worked on for PCD.
-Ben
microlo75
PostPosted: Fri Apr 16, 2010 10:12 am     Reply with quote
-Ben
The problem is that I've done a lot of code with CCS compiler and change is difficult ...
I hope someone on the Forum has already had experience and can help me ....
thanks Crying or Very sad
