question about Hyperterminal
curiousaboutcircuits85
PostPosted: Wed Apr 14, 2010 6:30 pm     Reply with quote
i've noticed that many people use hyperterminal to test their codes on their pics. I've never used it before, can anybody direct me into setting this up so that i could make my life easier Smile thanks!
dezso
PostPosted: Wed Apr 14, 2010 6:43 pm     Reply with quote
There is a million examples out there, check section 5.
I'm could be wrong many time's, at least I know what I'm doing Smile
PostPosted: Wed Apr 14, 2010 6:49 pm     Reply with quote
How to setup Hyperterminal:
http://www.ccsinfo.com/forum/viewtopic.php?t=9253&start=1
Instructions for downloading and installing an alternate Terminal
program called TeraTerm (more reliable than Hyperterminal):
http://www.ccsinfo.com/forum/viewtopic.php?t=39388&start=18
Here is the CCS FAQ article on RS-232 problems:
http://www.ccsinfo.com/faq.php?4
Here is a schematic of a MAX232 circuit:
http://web.ukonline.co.uk/j.winpenny/pic/rs232x.gif
Note that if you're using a MAX232A, then you should use 0.1 uF
capacitors, instead of the 1 uF caps.
Douglas Kennedy
PostPosted: Wed Apr 14, 2010 7:31 pm     Reply with quote
TeraTerm (more reliable than Hyperterminal) is an under statement
1000 times more reliable than hyperterminal maybe more accurate.
Wayne_
PostPosted: Thu Apr 15, 2010 2:44 am     Reply with quote
Avoid hyperterm where possible, it was one of the worst things microsoft ever did to replace windows terminal with the absolute crap that is hyperterm.
arunb
re
PostPosted: Thu Apr 15, 2010 7:36 am     Reply with quote
yes, TeraTerm is the greatest apart from a myriad of features it is also very reliable.
sjb
PostPosted: Thu Apr 15, 2010 11:49 am     Reply with quote
I would agree that HyperTerminal should be avoided if at all possible.
PuTTY is an alternative. I've used PuTTY for quite a few years while without problems. I've not used TeraTerm so can't compare it with PuTTY.
dezso
PostPosted: Thu Apr 15, 2010 1:17 pm     Reply with quote
I don't have definite numbers but I'm sure at least a 100 Million people used at some time in their life ! How about your app ? 1000?10000?100000?
Try this one no need to install.
And for Hyperterm, it works, maybe not for commercial use but works. Arrow
bkamen
PostPosted: Thu Apr 15, 2010 10:50 pm     Reply with quote
I use RealTerm as another option... hyperterm is terrible.
-Ben
SherpaDoug
PostPosted: Fri Apr 16, 2010 6:06 am     Reply with quote
Hyperterm for OS/2 was great. When they ported it to Windows was when it went bad.
bkamen
PostPosted: Fri Apr 16, 2010 7:20 am     Reply with quote
OS/2 -- what a fine piece of work.
I remember the days of using v4 while all my windows friends were crashing all around me.
*sigh*
newguy
PostPosted: Fri Apr 16, 2010 9:21 am     Reply with quote
Yeah, what a piece.....work doesn't spring to my mind though.
I was forced to use IBM PS2's running OS/2. I remember being forced to buy microchannel GPIB boards which cost about 3x that of non-IBM proprietary hardware protocol boards. And I had to compile C code with a weird crappy IBM compiler.
When I left that job I swore I'd never touch anything with IBM stamped on it ever again. Same goes for Lenovo now.
bkamen
PostPosted: Fri Apr 16, 2010 9:34 am     Reply with quote
I've been in that camp too - It's amazing the things IBM can create and utterly screw up at the same time.
I started fixing IBM PC's back in the mid 80's and quickly grew the same resentment as you.
But OS/2 compared to Win95 ... well, I used it. I know. There IS no comparison. OS/2 was the winner from the stability standpoint. But they lost the developer game to MS's FUD (another IBM created "-ism").
It's utterly stupifying to me that what made the PC market EXPLODE (widely available, low cost cards) that KILLED IBM's share in it (that they created BTW, giving away the sch's for the PC design) but kept Apple afloat for so many years -- only to turn hoards of people into lemmings willing to buy anything with an Apple stamp on it, no matter that Apple switched to a Unix variant.
CLOSED HARDWARE. LESS OPTIONS. CAPTIVE AUDIENCE.
No one likes being part of those 3 concepts.
But that's Apple -- in a nutshell -- today. IBM got burned on it so many years ago and it's amazing how I hear people complain about the concept (rightfully) -- but yet people still mindlessly stream towards Apple [spam].
So funny..
Sorry - I fell OffTopic in a big way.
-Ben
