Displaytech 240320G Driver (SED13700)
modus83
PostPosted: Tue Apr 13, 2010 1:44 pm     Reply with quote
Hi!
I'm finishing my career project and I have to use this GLCD.
But It doesn't show anything. I have check the connections a lot of times and I think this is not the problem.
I use this library:
http://www.ccsinfo.com/forum/viewtopic.php?t=28830&highlight=s1d13700
But it doesn´t works!!
I have SED1335.c also. Do anybody know what are the exactly changes to do in this library to get SED13700?. (I know M1 bit System_set register but I don´t know what changes I have to do).
O someone who has sed13700 library tested....
Please somebody help me!
It´s very important..
(Sorry for my english....)
modus83
PostPosted: Wed May 19, 2010 11:09 am     Reply with quote
Nobody????
I'm so worried. Someone who has SED13700.c code?
Any example?? Please, help
Rolling Eyes Rolling Eyes Rolling Eyes Rolling Eyes Rolling Eyes
PostPosted: Wed May 19, 2010 12:44 pm     Reply with quote
Post your compiler version. You can find it at the top of the .LST file in
your project directory. The version number is in this format: x.xxx
If your version is 4.021 or later, then the following routines are bugged
and will not work with those versions. The lines shown in bold are the
problem. Before vs. 4.021, CCS assumed all pointers were byte pointers
with respect to doing pointer arithmetic. But this is not the C standard.
They fixed this problem starting with vs. 4.021. The side effect is that
old code is "broken" when you use it with vs. 4.021 or later. It needs
to be edited and fixed.
// Purpose: Get the current address of the cursor
// Outputs: A 16 bit integer containing the cursor address
int16 getCursorAddress()
int16 addr;
glcd_sendCMD(GLCD_CMD_GET_CSR_ADDR);
TGLCD_COMMAND //CORRECAO - MODIFIED LINE
// TGLCD_DATA; //CORRECAO
*(int8*)(&addr ) = glcd_readByte(); // Read low part
*(int8*)(&addr + 1) = glcd_readByte(); // Read high part
return addr;
// Purpose: Set the cursor address
// Inputs: A 16 bit integer containing the new cursor address
void setCursorAddress(int16 addr)
glcd_sendCMD(GLCD_CMD_SET_CSR_ADDR);
TGLCD_DATA
glcd_sendByte(*(int8*)(&addr ));
glcd_sendByte(*(int8*)(&addr + 1));
Here are the new, edited routines. These will work with compiler
vs. 4.021 and later:
   int16 addr;
   *((int8*)&addr + 1) = glcd_readByte();  // *** Fixed pointer arithmetic
   return addr;
   TGLCD_DATA
   glcd_sendByte(*((int8*)&addr + 1));   // *** Fixed pointer arithmetic
modus83
PostPosted: Thu May 20, 2010 7:52 am     Reply with quote
Thank you so much!
I have 4.058 compiler version....so...I'm going to update with your code.
The modifications are correct (CORREÇAO)?
I have changed the C/R and TC/R parameters because my screen is 240x320, not 320x240 pixels.... and I'm using a 20 Mhz crystal.
Anyway, I think that it is not going to work.....
I only want that one pixel puts ON!!!
Thank you for answer....
modus83
PostPosted: Tue May 25, 2010 12:37 pm     Reply with quote
Your solution does not work. The issue is that it shows no
pixel ... nothing. The microcontroller is working properly (18F2550) because
the test LED turns on, but the screen does nothing ...
I have checked a thousand times the connections and everything seems fine ...
I'm going crazy ... what surprises me is not displaying
absolutely nothing ...
I'm going to post the code if anyone can help ....
#ifndef SED13700
#define SED13700
#ifndef GLCD_WIDTH
#define GLCD_WIDTH         320
#else
   #if GLCD_WIDTH>256
   #define LARGE_LCD
   #endif
#endif
#ifndef GLCD_HEIGHT
#define GLCD_HEIGHT        240
#else
   #if GLCD_HEIGHT>256
      #ifndef LARGE_LCD
      #define LARGE_LCD
      #endif
   #endif
#endif
#ifndef GLCD_CHAR_WIDTH
#define GLCD_CHAR_WIDTH    8
#endif
#ifndef GLCD_CHAR_HEIGHT
#define GLCD_CHAR_HEIGHT   8
#endif
#ifndef GLCD_RST
#define GLCD_RST           PIN_C0
#endif
#ifndef set_tris_lcd
#define set_tris_lcd       set_tris_b
#endif
#ifndef input_lcd
#define input_lcd          input_b
#endif
#ifndef output_lcd
#define output_lcd         output_b
#endif
#ifndef GLCD_RD
#define GLCD_RD            PIN_A2
#endif
#ifndef GLCD_WR
#define GLCD_WR            PIN_A1
#endif
#ifndef GLCD_CS
#define GLCD_CS            PIN_A3
#endif
#ifndef GLCD_A0
#define GLCD_A0            PIN_A0
#endif
#ifndef ON
#define ON                 1
#endif
#ifndef OFF
#define OFF                0
#endif
#define _t1                1
#define _t2                2
// The following defines setup the memory used by different regions
// Currenty one text area is defined at the beginning of memory
// and a graphics area follows immediately after
#define GLCD_TEXT_ADDR              0x0000
#define GLCD_GRAPHICS_ADDR          GLCD_WIDTH * GLCD_HEIGHT / 64
#define GLCD_GRAPHICS_ADDR_END      GLCD_GRAPHICS_ADDR + (GLCD_WIDTH * GLCD_HEIGHT / 8)
#if GLCD_CHAR_WIDTH < 9
   #define GLCD_CR (GLCD_WIDTH/8 - 1)
#else
   #define GLCD_CR (GLCD_WIDTH/4 - 2)
#endif
#define TGLCD_COMMAND   output_high(GLCD_A0);
#define TGLCD_DATA      output_low(GLCD_A0);
int8  glcd_readByte();
void  glcd_sendByte(int8 data);
void  glcd_fillScreen(int1 color);
void  glcd_fillScreenText(char c);
void  setCursorAddress(int16 addr);
void  glcd_pixel(int16 x, int16 y, int1 color);
void  glcd_sendCMD(int8 cmd);
int16 getCursorAddress();
int8  getData(int16 addr);
int8  getStatus();
void  glcd_systemSetup();
void  glcd_scrollSetup();
void  glcd_overlaySetup();
void  glcd_power(int1 mode);
void  glcd_cursorDirection(int8 dir);
void  glcd_cursorForm(int8 width, int8 height);
void  setData(int16 addr, int8 data);
#define GLCD_CMD_SYSTEM          0x40  // General system settings
#define GLCD_CMD_SLEEP           0x53  // Enter into standy mode
#define GLCD_CMD_DISP_OFF        0x58  // Turn the display off
#define GLCD_CMD_DISP_ON         0x59  // Turn the display on
#define GLCD_CMD_SCROLL          0x44  // Setup text and graphics address regions
#define GLCD_CMD_CSR_FORM        0x5D  // Set cursor size
#define GLCD_CMD_CSRDIR_RIGHT    0x4C  // Cursor moves right after write to display memory
#define GLCD_CMD_CSRDIR_LEFT     0x4D  // Cursor moves left after write to display memory
#define GLCD_CMD_CSRDIR_UP       0x4E  // Cursor moves up after write to display memory
#define GLCD_CMD_CSRDIR_DN       0x4F  // Cursor moves down after write to display memory
#define GLCD_CMD_CGRAM_ADDR      0x5C  // Configure character generator RAM address
#define GLCD_CMD_HDOT_SCR        0x5A  // Set horizontal scroll rate
#define GLCD_CMD_OVERLAY         0x5B  // Configure how layers overlay
#define GLCD_CMD_SET_CSR_ADDR    0x46  // Set the cursor address
#define GLCD_CMD_GET_CSR_ADDR    0x47  // Read the cursor address
#define GLCD_CMD_DISPLAY_WRITE   0x42  // Write to display memory
#define GLCD_CMD_DISPLAY_READ    0x43  // Read from display memory
// Purpose:       Initialize the controller
// Inputs:        The initialization mode
//                OFF - Turns the LCD off
//                ON  - Turns the LCD on
void glcd_init(int1 mode)
   // Initialze some pins
   #ifdef GLCD_RST      //Sup?e que o dispositivo ja foi resetado
      output_low (GLCD_RST);
      delay_ms (1);
      output_high(GLCD_RST);
      delay_ms (1);
   #endif
   output_high(GLCD_CS);
   output_high(GLCD_RD);
   output_high(GLCD_WR);
   glcd_systemSetup();
   glcd_scrollSetup();
   glcd_power(OFF);
   glcd_fillScreenText(' ');
   glcd_fillScreen(OFF);
   glcd_cursorForm(4, 6);
   glcd_power(mode);
   glcd_cursorDirection(GLCD_CMD_CSRDIR_RIGHT);
// Purpose:       Turn a pixel on a graphic LCD on or off
// Inputs:        x - the x coordinate of the pixel
//                y - the y coordinate of the pixel
//                color - ON or OFF
   int8  data;
   int16 addr;
   // Calculate the byte address containing the pixel
   addr = GLCD_GRAPHICS_ADDR + (GLCD_WIDTH/8 * y + x/8);
   // Read the byte of data at the address
   data = getData(addr);
   // Turn the pixel on or off
   if(color == ON)
      bit_set(data, 7 - x%8);
      bit_clear(data, 7 - x%8);
   // Write the new data byte to display memory
   setData(addr, data);
// Purpose:    Initialize the display environment
   glcd_sendCMD(GLCD_CMD_SYSTEM);          // Setup the system
   TGLCD_DATA                              // Set for data
   glcd_sendByte(0x30); // No offset
   glcd_sendByte(0x7F + GLCD_CHAR_WIDTH);  // Set character width
   glcd_sendByte(GLCD_CHAR_HEIGHT - 1);    // Set character height
   glcd_sendByte(GLCD_CR);                 // Display line address range
   glcd_sendByte(0x9A);                    // TC/R (Antes ponía 2F)
   glcd_sendByte(GLCD_HEIGHT - 1);         // Number of lines per frame
   glcd_sendByte(GLCD_CR + 1);             // Horizontal address range LSB (APL)
   glcd_sendByte((GLCD_CR + 1) / 0xFF);    // Horizontal address range MSB (APH)
// Purpose:    Set the scroll start address and
//             the size of a scroll block
   // Currently setup for a text and graphics layer
   glcd_sendCMD(GLCD_CMD_SCROLL); // Setup scrolling
   glcd_sendByte(GLCD_TEXT_ADDR);              // SAD1L
   glcd_sendByte(GLCD_TEXT_ADDR / 0xFF);       // SAD1H
   glcd_sendByte(GLCD_HEIGHT - 1);             // SL1
   glcd_sendByte(GLCD_GRAPHICS_ADDR);          // SAD2L
   glcd_sendByte(GLCD_GRAPHICS_ADDR / 0xFF);   // SAD2H
   glcd_sendByte(GLCD_HEIGHT - 1);             // SL2
   glcd_sendByte(0x00);                        // SAD3L
   glcd_sendByte(0x00);                        // SAD3H
   glcd_sendByte(0x00);                        // SAD4L
   glcd_sendByte(0x00);                        // SAD4H
   glcd_sendCMD(GLCD_CMD_HDOT_SCR);// Horizontal scroll rate
   glcd_sendByte(0x00);                        // Horizontal pixel shift is 0
// Purpose:    Setup the overlay functionality for combining
//             layers of text and graphics, or multiple
//             graphics layers
   // Currently setup for a single graphics layer
   glcd_sendCMD(GLCD_CMD_OVERLAY);              // Text / graphic overlay mode
   glcd_sendByte(0x00);                         // Area 1 text, others graphics
                                                // Text XOR Graphics
// Purpose:    Turn the display on or off
// Inputs:     ON to turn on or OFF to turn off
   if(mode == ON)
      glcd_sendCMD(GLCD_CMD_DISP_ON);           // Turn the display on
      glcd_sendCMD(GLCD_CMD_DISP_OFF);          // Turn the display off
   glcd_sendByte(0x16);
// Purpose:    Set the direction the cursor moves after
//             writing to dispaly memory
// Inputs:     Use one of the following to set the direction:
//             GLCD_CMD_CSRDIR_RIGHT
//             GLCD_CMD_CSRDIR_LEFT
//             GLCD_CMD_CSRDIR_UP
//             GLCD_CMD_CSRDIR_DOWN
   glcd_sendCMD(dir);
// Purpose:    Set the size of the cursor
// Inputs:     1) The width in pixels - 1  Valid numbers: (0 - 15)
//             2) The height in pixels - 1 Valid numbers: (1 - 15)
   glcd_sendCMD(GLCD_CMD_CSR_FORM);             // Cursor form and size
   glcd_sendByte(width);
   glcd_sendByte(0x80 + height);
// Purpose:    Fill a graphics layer passed in color
//             Works much faster than drawing a rectangle to fill the screen
// Inputs:     ON - turn all the pixels on
//             OFF - turn all the pixels off
   int16 i;
   setCursorAddress(GLCD_GRAPHICS_ADDR);
   glcd_sendCMD(GLCD_CMD_DISPLAY_WRITE);
   TGLCD_DATA
   for(i = GLCD_GRAPHICS_ADDR; i < GLCD_GRAPHICS_ADDR_END; ++i)
      glcd_sendByte(0xFF * color);
// Purpose:    Fill a text layer with a the passed in character
   int16 i;
   setCursorAddress(GLCD_TEXT_ADDR);
   TGLCD_DATA
   for(i = GLCD_TEXT_ADDR; i < GLCD_GRAPHICS_ADDR; ++i)
      glcd_sendByte(c);
// Purpose:    Write a byte of data
// Inputs:     The byte of data to write
void glcd_sendByte(byte data)
   output_lcd((data));
   output_low(GLCD_CS);
   delay_cycles(_t1);
   output_low(GLCD_WR);
   delay_cycles(_t2);
   output_high(GLCD_CS); //POR MI
// Purpose:    Read a byte of data
// Outputs:    The byte of data
   byte data;
   set_tris_lcd(0xFF);
   output_high(GLCD_WR); //POR MI
   delay_cycles(_t1);
   output_low(GLCD_RD);
   data = input_lcd(); //POR MI cambio orden
   delay_cycles(_t2);
   return data;
// Purpose:    Get the status
// Outputs:    The status in an 8 bit integer
int8 getStatus()
   int8 status;
   TGLCD_DATA
   delay_us(_t1);
   status = input_lcd();
   return status;
   int16 addr;
   return addr;
   TGLCD_DATA
// Purpose:    Get a byte of data from the display at the address
// Inputs:     A 16 bit integer containing the address
// Outputs:    An 8 bit integer with the read data
   setCursorAddress(addr);
   glcd_sendCMD(GLCD_CMD_DISPLAY_READ);
   //TGLCD_DATA      //CORRECAO
   return glcd_readByte();
// Purpose:    Set a byte of display data at an address
// Inputs:     1) A 16 bit address
//             2) 8 bits worth
   TGLCD_DATA
   glcd_sendByte(data);
// Purpose:    Send an 8 bit command
// Inputs:     The command to send
   TGLCD_COMMAND
   glcd_sendByte(cmd);
#endif
Are ok the MODIFICATION LINES (getData and getAdress)??
The main program is:
#include <18f2550.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOMCLR
#include "SED13700_JORDI.c"
#include "graphics.c"
void main() {
   delay_ms (100);
   glcd_init(ON);
   while (TRUE)
   glcd_rect (0,0,100,100,1,1);
   delay_ms (1000);
   glcd_fillscreen (0);
Thank you so much for your help, friends!!
Bye
PostPosted: Tue May 25, 2010 2:48 pm     Reply with quote
I assume this is the data sheet for your LCD.
http://www.displaytech.com.hk/upload/product/attachment/1024-240320g%20series-v21.pdf
Look on page 9. It shows the jumper and configuration options for the
LCD. It shows that the default interface is the Motorola interface. It says:
M6800 Family Bus Interface (Default)
This interfaces uses E, R/W, and RS (A0). But the driver that you have
posted uses the Intel-style interface, which uses RD, WR, CS, A0.
That explains why nothing works. The LCD is jumpered for the Motorola
interface, and you're using the Intel-interface driver.
So the solution is:
1. Change the jumper (or a solder-bridge across 2 pads) configuration
on the LCD to Intel mode (DisplayTech calls it "generic" interface).
or
2. Find another driver that works in Motorola mode.
or
3. Convert the existing driver to Motorola mode.
modus83
PostPosted: Tue May 25, 2010 4:15 pm     Reply with quote
So the solution is:
or
or
Thank you so much for your answer!! Tomorrow morning I'm going to change
the CNF to Intel interface.
If I don´t know how to do that, surely I will try to convert my driver to the M6800 language.
I haven´t seen it before!! Hopefully it works!!
Regards
modus83
PostPosted: Wed May 26, 2010 5:51 am     Reply with quote
It doesn't works.... Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad Crying or Very sad
Maybe "Generic bus" is not 8080 interface....
I'm going to try convert the code into 6800 format...
Then:
#RD = E
#WR = R/#W
A0 = A0
#CS = #CS
#RST = #RST
is it correct?
So, this:
   output_low (GLCD_A0); //Data
   output_lcd((data));
   delay_cycles(_t1);
   delay_cycles(_t2);
Should be....
   output_low (GLCD_RW);
   output_lcd((data));
   output_high (GLCD_E);
   delay_cycles( 2 );
   output_low (GLCD_E);
   delay_cycles( 2 );
msakms
PostPosted: Mon Dec 12, 2011 5:14 pm     Reply with quote
I've had a similar issue so, may be this will work for you. Try making a short between the Vdd "+ve supply" and the V0 "Pin 18" then release. See if that shows anything on your GLCD. I had a contrast adjustment issue although I followed the datasheet to the letter.
Good luck.
