compiler bug?? at clear_interrupt( INT_RBx );
YASU
PostPosted: Sun Apr 11, 2010 8:12 pm     Reply with quote
Now I got trouble that I could not clear interrupt flag by using
I think this is compiler bug.
Please give me some advice, and show me how to solve it.
Device PIC16LF1937
software
MPLAB 8.46
CCS C PCM 4.104/4.105
I make isr as following.
void rb_isr( void )
   ucDummy = input_b();
   disable_interrupts( INT_RB0 );
   disable_interrupts( INT_RB1 );
   disable_interrupts( INT_RB2 );
   disable_interrupts( INT_RB5 );
   disable_interrupts( INT_RB6 );
   disable_interrupts( INT_RB7 );
   disable_interrupts( INT_RB );
   clear_interrupt( INT_RB0 );
   clear_interrupt( INT_RB1 );
   clear_interrupt( INT_RB2 );
   clear_interrupt( INT_RB3 );
   clear_interrupt( INT_RB4 );
   clear_interrupt( INT_RB5 );
   clear_interrupt( INT_RB6 );
   clear_interrupt( INT_RB7 );
   clear_interrupt( INT_RB );
And I checked disassembly list, then
it seems like clear PIR2 register CCP2IF bit.
912:               #int_rb
913:               void rb_isr( void )
914:               {
915:                  ucDummy = input_b();
  0051    30FF     MOVLW 0xff
  0052    0021     MOVLB 0x1
  0053    008D     MOVWF 0xd
  0054    0020     MOVLB 0
  0055    080D     MOVF 0xd, W
  0056    00AF     MOVWF 0x2f
916:                  disable_interrupts( INT_RB0 );
  0057    0027     MOVLB 0x7
  0058    1014     BCF 0x14, 0
  0059    1015     BCF 0x15, 0
917:                  disable_interrupts( INT_RB1 );
  005A    1094     BCF 0x14, 0x1
  005B    1095     BCF 0x15, 0x1
918:                  disable_interrupts( INT_RB2 );
  005C    1114     BCF 0x14, 0x2
  005D    1115     BCF 0x15, 0x2
919:                  disable_interrupts( INT_RB5 );
  005E    1294     BCF 0x14, 0x5
  005F    1295     BCF 0x15, 0x5
920:                  disable_interrupts( INT_RB6 );
  0060    1314     BCF 0x14, 0x6
  0061    1315     BCF 0x15, 0x6
921:                  disable_interrupts( INT_RB7 );
  0062    1394     BCF 0x14, 0x7
  0063    1395     BCF 0x15, 0x7
922:                  disable_interrupts( INT_RB );
  0064    0194     CLRF 0x14
  0065    0195     CLRF 0x15
923:                  clear_interrupt( INT_RB0 );
  0066    0020     MOVLB 0
  0067    1012     BCF 0x12, 0
924:                  clear_interrupt( INT_RB1 );
  0068    1012     BCF 0x12, 0
925:                  clear_interrupt( INT_RB2 );
  0069    1012     BCF 0x12, 0
926:                  clear_interrupt( INT_RB3 );
  006A    1012     BCF 0x12, 0
927:                  clear_interrupt( INT_RB4 );
  006B    1012     BCF 0x12, 0
928:                  clear_interrupt( INT_RB5 );
  006C    1012     BCF 0x12, 0
929:                  clear_interrupt( INT_RB6 );
  006D    1012     BCF 0x12, 0
930:                  clear_interrupt( INT_RB7 );
  006E    1012     BCF 0x12, 0
931:                  clear_interrupt( INT_RB );
  006F    1012     BCF 0x12, 0
I think it sould be like as followings
922:    clear_interrupt( INT_RB0 );
    MOVLB 7
    BCF 0x16, 0
923:   clear_interrupt( INT_RB1 );
    BCF 0x16, 1
924: clear_interrupt( INT_RB2 );
    BCF 0x16, 2
925:  clear_interrupt( INT_RB3 );
    BCF 0x16, 3
926:    clear_interrupt( INT_RB4 );
    BCF 0x16, 4
927:    clear_interrupt( INT_RB5 );
    BCF 0x16, 5
928:   clear_interrupt( INT_RB6 );
    BCF 0x16, 6
929:   clear_interrupt( INT_RB7 );
    BCF 0x16, 7
Someone help me.
PostPosted: Mon Apr 12, 2010 1:15 pm     Reply with quote
Yes there is a bug. It's still there in vs. 4.106. You need to report it
to CCS tech support. Send them an email.
