I'm a newbie and I'm trying to learn to program with C.
What's the best way to avoid getting lots of ones when you push a button or get a signal from a sensor? interruption with RB0? or a delay? (I don't like delays because I need the program to keep running) or is there an edge function?
Thanks for your help
Thanks for your help.
What if using your button.c code I don't want the delay and the auto-repeat to work?
I want to make a counter which only counts once when the button is pressed, the button could stay pressed indefinitely.
danielpepo
Posted: Wed Apr 14, 2010 3:13 am
I just found out if I load 255 on delay, it doesn't repeat.
I couldn't understand one thing from your button code, How can you know 50 would be 500ms and so on?
Posted: Wed Apr 14, 2010 10:38 am
Look in the while() loop in the main program. It has a delay_ms(10)
statement at the end. This means the counters will count in 10ms
increments. A count of 50 gives 50 x 10ms = 500 ms.
