Оccupies a large part of the ROM :(
MegatroniC
View user's profile Send private message ICQ Number
PostPosted: Mon Apr 12, 2010 5:29 am     Reply with quote
Hello. Smile
This fragment of my code occupies 20% ROM. (Here most of the code)
How can I optimize?
void detect_buttons1(void)
 if(scroll_click)                                  // 1%
   switch(adc_channel)
     case 0: adc_channel=1;
     case 1: adc_channel=2;
     case 2: adc_channel=3;
     case 3: adc_channel=0;
  if(select_click) time_data();        //  19%
  if(set_hold) main_menu();          //
thanks Smile
mskala
PostPosted: Mon Apr 12, 2010 8:22 am     Reply with quote
I'm pretty sure people have written a more compact printf replacement that saves code space by not having to deal with floats, etc. You should look into that.
PostPosted: Mon Apr 12, 2010 8:28 am     Reply with quote
You have already marked that 'time_data' is occupying 19%.
Your chip only has a small amount of memory. The print statements in this, are the big 'memory hogs'.
You might find they would code smaller, by using a separate 'printval' function, that just outputs a single int8, and calling this in turn for each value, and just using putc, to send the extra characters between. This way one single print function does 80% of the work.
Your 'switch' can be coded smaller as:
adc_channel=(adc_channel+1)&3;
