#byte and #bit
msa
#byte and #bit
PostPosted: Sat Apr 10, 2010 10:07 am     Reply with quote
Dear all
I have 18f2550. I need to use #byte and #bit to name my pins.
My code :
#include <18F2550.h>
#use delay(clock=8000000)
#FUSES NOWDT                       //No Watch Dog Timer
#FUSES INTRC_IO                       //Internal RC Osc
#FUSES NOPROTECT                   //Code not protected from reading
#FUSES NODEBUG                     //No Debug mode for ICD
#FUSES NOLVP                       //No low voltage prgming, B3(PIC16)
#FUSES NOMCLR                        //Master Clear pin disabled
#byte PORTA=0xF80
#bit led1=PORTA.0
#bit led2=PRATA.1
#bit led3=PORTA.2
void main(void){
setup_oscillator(OSC_8MHZ);
for(;;){
output_high(led1);
output_high(led2);
output_high(led3);
output_low(led1);
output_low(led2);
output_low(led3);
but this code not working.
thanks
taner_73
View user's profile Send private message ICQ Number
PostPosted: Sat Apr 10, 2010 10:45 am     Reply with quote
first this is wrong:
#bit led2=PRATA.1
and should be:
#bit led2=PORTA.1
and second this code block:
output_high(led1);
output_high(led2);
output_high(led3);
should be:
led1=1;
led2=1;
led3=1;
and this:
output_low(led1);
output_low(led2);
output_low(led3);
should be:
led1=0;
led2=0;
led3=0;
Best regards,
Taner
Smile
PostPosted: Sat Apr 10, 2010 12:53 pm     Reply with quote
Add, third, if you are talking directly to the pins, then _you_ have to control the TRIS.
msa
PostPosted: Sat Apr 10, 2010 12:56 pm     Reply with quote
Hi taner_73
Hi Ttelmah
Thanks for your answers.
It is now working.
My code after update:
#FUSES NOLVP                       //No low voltage prgming, B3(PIC16) or
#byte PORTA=0xF80
#bit led1=PORTA.0   // bit 0
#bit led2=PORTA.1   // bit 1
#bit led3=PORTA.2   // bit 2
void main(void){
SET_TRIS_A(0xF8); // 1111 1000
output_a(0);
for(;;){
led1=1;delay_ms(500);led1=0;
led2=1;delay_ms(500);led2=0;
led3=1;delay_ms(500);led3=0;
thiam
PostPosted: Sat Apr 10, 2010 8:59 pm     Reply with quote
What is difference between #bit and #byte ?
