have trouble with PIC18F4331 in receive signal from encoder
thiam
PostPosted: Fri Apr 09, 2010 7:29 am     Reply with quote
hi, I have a trouble in develop PIC18F4331 in receive signal from rotary encoder. The channel phase A and B are used only. Below is the sample code and circuit for PIC16F877A which has build external decode.
#include <16F877A.h>
#include <string.h>
#fuses hs, noprotect, nowdt,nolvp
#byte PORTB=6
#byte PORTC=7
#define door PIN_B2
#define window PIN_B1
#define bumper PIN_B3
#define REDLED PIN_B4
#define GREENLED PIN_B6
#define YELLOWLED PIN_B3
#define DIRECTION PIN_D7
#include <input.c>
#include <stdlib.h>
#define STRING_SIZE 40
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
long t0 = 0;
long t1 = 1;
byte bgetc()
   byte c;
   while(!bkbhit) ;
   c=buffer[next_out];
   return(c);
void get_cmd_str(char * s, int max) {
   int len;
   char c;
   max--;
   len = 0;
   do {
      c = bgetc();
      if(c > 0x00) {
         if(len < max) {
            s[len++] = c;
   while(bkbhit);
   s[len]= 0x00;
#int_rda
void serial_received()
   int t;
   buffer[next_in]=getc();
   t=next_in;
   if(next_in==next_out)
     next_in=t;           // Buffer full !!
#int_ext
void interrupt()
BYTE  time3;
set_tris_b(0b00000001);
output_high(bumper);
time3 = get_timer0();
time3 += -1;
set_timer0(time3);
#int_rtcc
void timer0_isr()
t0 += 1;
#int_timer1
void timer1_isr()
t1 += 1;
set_timer1(0xFF00);
setup_timer_2(T2_DIV_BY_16, 127, 1);
setup_counters( RTCC_EXT_H_TO_L, RTCC_DIV_1 );
set_rtcc(0);
setup_timer_1 ( T1_EXTERNAL | T1_DIV_BY_1 );
set_timer1(0xFFF4);
enable_interrupts(INT_RTCC);
EXT_INT_EDGE(L_TO_H);
ENABLE_INTERRUPTS(INT_EXT);
ENABLE_INTERRUPTS(INT_RDA);
main_program:
do
printf("%2x",t0);
printf("%2x",get_rtcc());
printf("%2x",t1);
printf("%2x\n\r",get_timer1());
output_high(GREENLED);
output_low(REDLED);
output_low(YELLOWLED);
}while(TRUE);
goto main_program;
http://www.flickr.com/photos/49158679@N02/4505396788/
Now, My problem is no idea to write the code in PIC18F4431.. Anyone can guide me about that?? thanks
