dual channel AD conversion in pic18F4331
Hicham
PostPosted: Thu Apr 08, 2010 2:42 pm     Reply with quote
I'm working with pic18F4331 and it has a multi-channel AD conversion.
Based on the datasheet, it has 4 places to save the value after conversion before putting them in the final registers (ADRESH,ADRESL),
in case of using dual or sequence conversion.
But I can't figure out how to get 2 values in the same time after a dual conversion in CCS.
Is there an example for this kind of conversion ?
Any examples code are much appreciated.
PostPosted: Thu Apr 08, 2010 6:26 pm     Reply with quote
The code shown below works with vs. 4.106. I don't have a 18F4331, so
I used an 18F4431, which is very similar. I set AN0 to 2.0 volts, and
AN1 to 3.0 volts. I get the following output on the terminal window:
Ch0 = 411, Ch1 = 627
Ch0 = 411, Ch1 = 626
This is basically correct, given an ADC output range from 0 to 1023
over a 0v to 5v range. 2.0v should be 409, and 3.0v should be 614.
My variable power supply can't put out exactly 3.00v. But close enough.
I don't guarantee that this program is exactly correct. I looked at the
data sheet and the .LST file, and keep playing with it until it worked and
until it looked like I was complying with the data sheet's instructions for
continuous dual sampling mode. But anyway, it's good enough to give
you a starting point. Remember, I don't want to do your project for you.
You must do any further work on it.
#include <18F4431.h>
#device adc=10
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
#byte ADCON1 = 0xFC1
#byte ADRESL = 0xFC3
#byte ADRESH = 0xFC4
#byte ADCHS  = 0xF99
#bit  ADC_FIFOEN = ADCON1.4
#bit  ADC_BFEMT  = ADCON1.3
int16 result0, result1;
// Select pins AN0 and AN1, in Groups A and B, respectively.
setup_adc_ports(sAN0 | SAN1);
// Tell ADC to read continuously from input Groups A and B.
setup_adc(ADC_CLOCK_DIV_2 | ADC_CONT_AB);
delay_us(10);  // Wait 10us, per the 18F4431 data sheet.
// Tell the ADC to put the conversion results in the fifo.
ADC_FIFOEN = 1;
read_adc(ADC_START_ONLY);  // Set the GO bit in ADCON0
   // Wait for the first A/D result to become available in the fifo.
   // Then read it.
   while(ADC_BFEMT);
   result0 =  make16(ADRESH, ADRESL);
   // Wait for the 2nd A/D result to become available in the fifo.
   // Then read it.
   while(ADC_BFEMT);
   result1 =  make16(ADRESH, ADRESL);
   printf("Ch0 = %lu, Ch1 = %lu \n\r", result0, result1);
Hicham
PostPosted: Sun Apr 11, 2010 8:19 am     Reply with quote
Thanks for this example, PCM programmer.
Now I understand how it works.
So, I have to create new bytes like "ADC_FIFOEN "
I thought they're already build-in CCS.
Anyway.. thanks for your help, and wait my new question soon.
