WDT Issue on 12F683
nmeyer
WDT Issue on 12F683
PostPosted: Wed Apr 07, 2010 4:27 pm     Reply with quote
I am having an issue with a the WDT and timer0 on the 12F683. I have a timer0 INT that i want to use to count seconds and after a preset time, turn off my output and put the chip to sleep. I want to use the WDT to wake up the chip every so often and check to see if it should be active again or go back to sleep. If the WDT is off, my second counter works fine. However, if i turn the WDT on, the PIC just locks up.
Compiler V. 4.086
#include <12F683.h>
#device *=16 ADC=10
#fuses INTRC_IO,NOWDT,NOPUT,NOPROTECT,NOMCLR,BROWNOUT
#use delay(clock=500000)
#define RAND_MAX 255
#define dusk  970
#define INTS_PER_SECOND  240     //976
#include <stdlib.h>
int8 count,loop_int,rand_start=1,loop_var;
long ambient_light;
long  seconds,hour,minute,int_count;
#int_timer0
void clock_isr(void)
   if(--int_count==0)                     //decrement counter until 0
      ++seconds;                          //count up seconds
      int_count=INTS_PER_SECOND;          //reset counter
      if (seconds>=65000)
         seconds=65000;
   setup_wdt(WDT_OFF);
   //setup_wdt(WDT_2304MS);
   setup_oscillator(osc_500khz);
   setup_adc_ports(sAN0);
   setup_ccp1(CCP_PWM);   // Configure CCP1 as a PWM
   setup_timer_2(T2_DIV_BY_1, 127, 1);
   set_adc_channel(0);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_2);
   set_timer0(0);
   enable_interrupts(INT_RTCC);
   /*setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
   set_timer1(0);
   enable_interrupts(INT_TIMER1);*/
   int_count=INTS_PER_SECOND;          //used for timer
   seconds=0;                          //clear out variable
   minute=0;                           //clear out minute counter
   hour=0;                             //clear low voltage counter for seconds
   /* Main Program */
   while (TRUE)
      if (rand_start==254)
         rand_start=1;
      else rand_start++;
      srand(rand_start);   // everytime this is called the seed will be initialized and the random sequence will be started
      loop_var=rand();
      ambient_light=read_adc();
      if(seconds>=5)
      //if (ambient_light>=dusk)
         loop_var=0;
         setup_ccp1(CCP_OFF);
         sleep();
         //seconds=0;
         //setup_ccp1(CCP_PWM);   // Configure CCP1 as a PWM
      for (loop_int=0;loop_int<loop_var;loop_int++)
         count=rand();
         if(count<20)
            count=20;
         set_pwm1_duty(count);
PostPosted: Wed Apr 07, 2010 5:43 pm     Reply with quote
Can you make a smaller test program ? If you could get rid of about
90% of the code it would be a lot easier to spot the problem. Smile
No, I'm serious. A smaller program makes it easier for us to solve the
problem by inspection.
#device *=16
Also, you don't need this line, because RAM in the 12F683 doesn't extend
beyond address 0xFF. You only need 16 bit pointers if you want to use
RAM at addresses 0x100 and above. (This option applies to 12F and 16F
PICs only. 18F PICs always use 16-bit pointers).
Wayne_
PostPosted: Thu Apr 08, 2010 1:55 am     Reply with quote
2 things,
Some PICs restart on a WDT from sleep have you checked your datasheet ?
When enabled it looks like you are using a 2304 ms WDT, you have a delay of 100 ms in your for loop, if loo_var > approx 23 this will cause your loop to take longer than 2304 ms and the WDT will restart your pic.
You can fix it by placing
restart_wdt()
in your loop or
#use delay (clock=500000, restart_wdt)
nmeyer
PostPosted: Thu Apr 08, 2010 3:50 pm     Reply with quote
Here is a shorter version. If the WDT is set to Off and the setup_wdt(wdt_2304ms) is commented out, the program will count up to 5 seconds and turn on the LED and go to sleep, but since the wdt is not turned on, it will stay asleep. If i change the fuse to WDT and use the setup_wdt(wdt_2304ms) the program no longer functions.
#include <12F683.h>
#device ADC=10
int   a;
#int_timer0
      if (seconds>=65000)
         seconds=65000;
   setup_wdt(WDT_OFF);           //I am chaning these two lines only and WDT
   //setup_wdt(WDT_2304MS);      //fuse from NOWDT to WDT
   set_timer0(0);
   output_low(PIN_A2);
   /* Main Program */
   while (TRUE)
      if(seconds>=5)
         output_high(PIN_A2);
         for(a=0;a<10;a++)
         sleep();
         seconds=0;
         output_low(PIN_A2);
PostPosted: Thu Apr 08, 2010 4:20 pm     Reply with quote
It looks to me like I was working on this problem for you back in 2007, LOL.
See my post at the end of this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=33089
In that program, WDT_TIMES_4 is used to give a 69ms timeout.
To get the 2304ms timeout, change it to WDT_TIMES_128.
Try the test program in the link above and see if that works.
nmeyer
PostPosted: Thu Apr 08, 2010 4:33 pm     Reply with quote
Yeah, I remember that. I was never able to get the WDT and the int_timer0 to work on that one either. I ended up turning off the WDT totally. I am reading that some parts share RTCC and WDT and I am wondering how that affects the set up and use.
PostPosted: Thu Apr 08, 2010 4:40 pm     Reply with quote
I probably tested the code in that link in hardware. Did you try that
exact code and it failed ?
nmeyer
PostPosted: Fri Apr 09, 2010 9:27 am     Reply with quote
Yes, that code does work. I have gone and stripped my code down and started adding things back in. I have it working as I intend for it to work at this point. I am not really sure what is different from what I posted the other day to what I have now, some slight differences in the code. But I do not see what caused it not to work the other day and let it work now. Thanks
