thiam
Do anyone know the coding for UC00A UART-USB Converter? |
Posted: Tue Apr 06, 2010 11:40 am |
Hi, I have no idea for the coding of UC00A UART-USB Converter.
the device can be bought from Cytron.. for more information about the device, pls refer to the website below.
http://www.cytron.com.my/listProducts.php?actionURL=&txtSearch=UC00A
Can someone guide me about the code for the device. I mean how to communiciate the PIC to PC through the device... Thank you!! |
bkamen
Posted: Tue Apr 06, 2010 11:42 am |
On the PC, what OS are you using? what does the application communicating with the PIC need to do?
What is the PIC doing? what kind of data does is send back?
Is you PC application just data logging? Heck - you could script that..
Or more?
You haven't given any real information as what you need.
Posted: Tue Apr 06, 2010 1:52 pm |
The said converter uses a FTDI FT232 and ships with FTDI standard drivers. You can refer to the documentation
provided by www.ftdichip.com and the discussion related to this device at CCS forum and allover the internet. |
thiam
Posted: Tue Apr 06, 2010 6:39 pm |
The OS I'm using is Windows XP. Then I need to communicate the PIC with my computer by using that device. Since I have tried the Serial port RS232, the communicate between PIC and my PC is function well. I need a simple application only. For example, the pin_B6 will on when i send a char like '1' from my computer to PIC... So, can you guide me about that??? thanks. |
Posted: Tue Apr 06, 2010 8:17 pm |
Your RS232 to USB adapter does not require any special programming.
Use the program shown below on your PIC. When you type a character
in the terminal window on the PC, it will go to the PIC, and then the PIC
will send it back to the terminal window.
Make these 3 connections between the PIC board and the UC00A:
1. Connect the Tx pin on the PIC to the Rx pin on the UC00A.
2. Connect the Rx pin on the PIC to the Tx pin on the UC00A.
3. Connect the Ground pin on the PIC board to the Ground pin
on the UC00A.
#include <16F877A.h>
#use rs232 (baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
char c;
c = getc(); // Get a character from the PC
putc(c); // Send the same character to the PC
bkamen
Posted: Tue Apr 06, 2010 8:35 pm |
Doesn't he want to test with kbhit? (as below?)
char c;
if ( kbhit() ) {
Posted: Tue Apr 06, 2010 8:43 pm |
getc() includes kbhit. getc() waits for a key to be pressed. Then it returns the value. |
bkamen
Posted: Tue Apr 06, 2010 8:54 pm |
PCM programmer wrote: | getc() includes kbhit. getc() waits for a key to be pressed. Then it returns the value. |
Oy - I've seen so many examples where kbhit() was needed.
Hmm, Even still.. if getc does nothing, won't putc(c); in that example keep streaming the last value of c regardless of what getc does?
Posted: Tue Apr 06, 2010 8:56 pm |
It doesn't do nothing. It waits for a key to be pressed. The program
will not advance beyond the getc() line until a key is pressed. |
bkamen
Posted: Tue Apr 06, 2010 9:32 pm |
Dang.
That's pretty funny.
I had seen so many examples of getc used with kbhit so long ago in the examples, I never actually looked at the help file for getc which indeed states:
This function waits for a character to come in over the RS232 RCV pin and returns the character. If you do not want to hang forever waiting for an incoming character use kbhit() to test for a character available. If a built-in USART is used the hardware can buffer 3 characters otherwise GETC must be active while the character is being received by the PICĀ®.
Learn something new every day. _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
thiam
Posted: Tue Apr 06, 2010 10:05 pm |
Thanks for your advice and codes. I have tried for both codes. With serial port, the code with kbhit() has no problem, but the another code can't run. However, both of the codes cannot run by using UC00A converter. Is the code missing something to communiciate with UC00A converter? |
Posted: Tue Apr 06, 2010 10:28 pm |
Download the User's Manual for the UC00A:
http://www.cytron.com.my/datasheet/PICStart-upKit/UC00A_User's_Manual.pdf
Look on page 11. It shows the Device Manager window for the Com Ports
on the PC. Find the Com Port which is assigned to the UC00A.
In the example shown in the User's Guide, it has the extreme case of
COM20 as the port. Normally, it will not be such a high port number.
Once you have learned the Com Port number for the UC00A, then go into
the Com Port setup menu in your Terminal program and select the same
Com Port. For example, if you are using TeraTerm, the Com Port is
selected in the Setup/General menu. After you have selected the
correct ComPort, the Terminal program can talk to the correct Com Port.
It should now work.
Of course, I assume that you also setup the correct baud rate in the
Terminal program setup menu, so it's the same as the baud rate in
your PIC program. |
thiam
Posted: Wed Apr 07, 2010 12:17 am |
Regarding to the port number, I have check and change. I have read the user manual. However, they just guide us to connect the UC00A to microcontroller. I have tried the code again after changing everything but still face the same problem. The signal from PC seems cannot transfer to microcontroller. Do you have any solution for it?? |
Posted: Wed Apr 07, 2010 12:48 am |
No. I don't have anything more to say. |
thiam
Posted: Wed Apr 07, 2010 2:11 am |
ok.. never mind... any way.. thank you so much |
