Is possible do this logic?
BotBoy
PostPosted: Tue Apr 06, 2010 10:47 am     Reply with quote
Hi...
An input can be the level 1 if is powered level 0 if is grounded.
Most the time I always do this logic of the input using 1 or 0.
Is possible have a 3rd input state?
Suppose I need only grounding some input pin (level 0) ,
how is possible verify when the pin not is grounded if never i will have a level 1
on this pin.
is possible do this logic?
if PIN is grounding
do something
if PIN not is grounding and dont have high level as input
do something
regards
lucasi
jbmiller
PostPosted: Tue Apr 06, 2010 10:59 am     Reply with quote
There are at least two ways to accomplish this.
First, easy, use an ADC or Comparator input pin.
Second, a little harder, is to sample the Input pin to check for the 'high-float' condition, 'tristate'...which is a trademark btw)
If you use Google, there will be tons of applications of this 'old school' technique to get more information with less pins.
hth
Jay
dezso
PostPosted: Tue Apr 06, 2010 11:01 am     Reply with quote
Yes.
I have done similar to check if the remote switch is connected or not.
Turn on the PWM if you pic has one, or just create a 1KHz osc from a 555,
feed the PWM or ext_osc output on a 1K resistor back to your input pin, probe your pin for 500ms to see if you have a pulsing cycles or steady low or high.
There is your 3 state.
1:low
2:high
3:pulsing
languer
PostPosted: Tue Apr 06, 2010 11:23 am     Reply with quote
To clarify, you want to determine if:
  • Pin is high,
  • Pin is low,
  • Or Pin is neither high or low - it's tri-stated (or not connected)
If this is the case look at Microchip's Tips'n Tricks 8-pin FLASH PIC Microcontrollers. In particular you're looking for TIP #3 Read Three States From One Pin.
If all you want to do is determine if:
  • Pin is low,
Then weakly pull-up the pin and test for HIGH or LOW.
BotBoy
PostPosted: Tue Apr 06, 2010 1:14 pm     Reply with quote
* Pin is low,
* Or Pin is neither high or low - it's tri-stated (or not connected)
Exactly it !...
I read the doc and implemented... works fine...
Thank you guys!
BotBoy
