rudy
18F4550 don't start, why? |
Posted: Sat Apr 03, 2010 3:19 pm |
Hi all,
I am changing one slave 16F877A for a new 18F4550. I tried everything to put the processor to start, but no deal, anybody can help me?
I use 20MHz crystal, and I need to run the chip as faster as possible. I don't use USB in my application.
Here are the fuses, I think the problem is here.
#fuses HSPLL,USBDIV,PLL5,CPUDIV1,VREGEN,NOWDT,NOPROTECT,NOLVP,NODEBUG
#use delay(clock=48000000)
Best regards. |
Posted: Sat Apr 03, 2010 9:59 pm |
Quote: |
I use 20MHz crystal.
First try blinking an LED with the PIC running at 20 MHz, as shown in
the program below. Does this work ?
#include <18F4550.h>
#fuses HS, NOWDT, PUT, BROWNOUT, NOLVP
// Blink an LED on pin B0.
output_high(PIN_B0);
output_low(PIN_B0);
If that works, change the fuses to run in PLL mode:
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,USBDIV,PLL5,CPUDIV1
output_low(PIN_B0);
rudy
Posted: Sun Apr 04, 2010 5:59 am |
Yes, the problem was the port address, I was calling 0x80 but, in 18F4550 is 0xf80.
works fine now,
regards. |
