dezso
RTC Alarm, How? |
Posted: Sat Apr 03, 2010 10:41 am |
Can't figure out how to check for time on my alarms.
What I was planning is to change the hr's to minute's, like 8:30 = 8*60+30=510 minute.
timer0 = 480 // 8:00
timer0_1 = 960 // 16:00
current time 540 //9:00
if current time > 480 and current time < 960
turn on
turn it of
It work until I set up the opposite way
current time 1020 //17:00
timer0 = 960 // 16:00
timer0_1 = 480 // 8:00
if current time > 960 and current time < 480
turn on
turn it of
timer0 = 480; timer0_1 = 1345; device0 = 1 ;
timer1 = 1380; timer1_1 = 500; device1 = 9;
void check_time()
if (ctimer >= timer0 && ctimer <= timer0_1)
bit_set(aqua_device,device0);
UpdateBtn(aqua_device);
bit_clear(aqua_device,device0);
if (ctimer >= timer1 && ctimer <= timer1_1)
bit_set(aqua_device,device1);
bit_clear(aqua_device,device1);
bungee-
Posted: Sat Apr 03, 2010 12:19 pm |
You could have one large integer that would hold your absolute seconds...
int32 absolute_secs; <-- This would work for another 136 years.
So you set this seconds to one fixed date and then you can calculate with that. You could use this also for daily time.... how many seconds passed from midnight.
So if you set alarm for 9:31:20 then the value you would be comparing for would be:
(3600*9)+(31*60)+21 ---> 34341 seconds
Also, it could be simplified and you would be setting alarm only on 00 seconds so you would count only minutes from midnight.....
Here are some thoughts about topic  |
Douglas Kennedy
Posted: Sat Apr 03, 2010 12:57 pm |
In 136 years from now some one will probably have taken this project to Mars. Will it work there? Just joking. |
dezso
Posted: Sat Apr 03, 2010 1:54 pm |
This alarms should repeat daily.
I don't worry about the seconds.
In basic I can do this:
Code: | Select Case hour2min
Case 0 To 479 ' 00:00 to 08:00 hr
Main_Light = 0
Second_Light = 0
Moon_Light = 1
Sump_light = 1
' Print At 1,10, "Moon Light/Sump Light ON"
Case 480 To 539 ' 08:00 to 09:00
Main_Light = 0
Second_Light = 0
Moon_Light = 1
Sump_light = 0
' Print At 1,10, "Sump Light OFF"
EndSelect |
Is it possible in C to have a range of case ? |
dezso
Posted: Sat Apr 03, 2010 1:58 pm |
Hold on, this will fail just like my original version.
Case 1439 To 1 ' 23:59 to 00:01 hr
isn't ? |
bungee-
Posted: Sat Apr 03, 2010 2:32 pm |
Ok, what do you want to do here with this code? Are you programming some sort timed power switch?
You have to set conditions according to 24h. Like this :
Code: | |00----02----04----06----08----10----12----14----16----18----20----22----|
______________________________________________________#############_____ | #--> On time, _ --> off time
This would be light turn on from 18 till 22 hours
If your light would need to be on trough the night like this: Code: | |00----02----04----06----08----10----12----14----16----18----20----22----|
################______________________________________################## | On from 18 till 5 in the morning....
In your code you would just check if the time meets condition and then you switch outputs accordingly.
Code: | if (time_of_day==480) //8:00
Light1(0);
Light2(1);
Light3(1);
if (time_of_day==600) //10:00
Light1(0); //If there is no change this is not necessary
Light2(0);
Light3(1); //If there is no change this is not necessary
You do not need to write switch (case) sentence, all you need are if terms and this is it  |
dezso
Posted: Sat Apr 03, 2010 5:30 pm |
Yes I should change the title to "24Hr Timer"
This is to turn on and off various device multiple time a day, currently using 8 old fashion mechanical timer like this one.
Anyway, thanks for the input.
I want the timers to be user selectable, so their value will change.
New approach:
Code: | timer0 = 1345; timer0_1 = 360; device0 = 1 ; |
void check_time()
if (ctimer == timer0) //Tun on time
if (ctimer == timer0_1) //Turn off time
Is there any way to add some redundancy/safety to be sure the selected device will not turn ON or OFF in the not selected time frame ?
dezso
Posted: Sat Apr 03, 2010 5:36 pm |
Super quick question, how can I convert the combined minute's to hr's &
min's ?
23:25 = (23*60)+25 = 1380 + 25 = 1405
1405 = 1405/60 = 23.4166666666 = 23 hr and 41 min, Grrrrr |
dezso
Posted: Sat Apr 03, 2010 5:45 pm |
Maybe :
ctimer = 1405;
for (i =ctimer; i > 61; i -60)
++hr;
min = i;
//on the end hr=23 min=25
will this one would work ?
My compiler no longer works, now just writing code.  |
dezso
Posted: Sat Apr 03, 2010 9:23 pm |
I think this should do the trick !?
ctimer = 944 // 15:44
lidiv=ldiv(ctimer,60);
//lidiv will contain lidiv.quot=15 and lidiv.rem=44 ?
This way I can scroll through all the timer setting and I can see the actual hr:min instead of the guff 944 |
